need help quick
Old Nov 5, 2007 | 05:40 PM
stangant's Avatar
stangant
Default need help quick
I just recived my mtx amp from ups. i hooked it up and now the sub is poping badly when i turn down the radio, change station, turn on/off. I have a panasonic h/u as well.
Old Nov 5, 2007 | 10:40 PM
ttocs's Avatar
ttocs
Default RE: need help quick
you should not have the gain set all the way up. no more then 2/3 to 3/4 full volume.
Old Nov 6, 2007 | 06:39 AM
stangant's Avatar
stangant
the gain is not set all the way up. i did have this problem with my old amp after i put the h/u in.
Old Nov 6, 2007 | 12:52 PM
ttocs's Avatar
ttocs
try wiggling your rca's on each end and see if it makes any noise. You might have a bad cable.
Give a complete list of all the equipment in your car. I don't want size shape or color, I want #'s.....
Old Nov 7, 2007 | 09:15 PM
stangant's Avatar
stangant
well i have 4 gauge power and ground wire and a normal remote wire. hope this helps
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
