fuse keeps blowing
Old Dec 2, 2007 | 05:51 PM
95 gustang's Avatar
95 gustang
Default fuse keeps blowing
my sub just stopped working this weekend, the fuse in the amp was blown so i replaced it but everytime i turn the car on one of the wires sparks and the fuse is blown again. any ideas on how to fix this?
Old Dec 2, 2007 | 06:23 PM
OldSkool's Avatar
OldSkool
Default RE: fuse keeps blowing
make sure that you have a good connection. if the wire that is sparking is shorting out somehow, that could cause the spark and the overload. check your ground wire and if you need to, take a metal file to remove any corrosion. this happened to me on my mach 1 and that's how i fixed it
Old Dec 2, 2007 | 07:26 PM
ttocs's Avatar
ttocs
and after that try disconnecting the sub and then replacing the fuse and powering it up. If your speaker wires are shorted it could cause this as well.
Old Dec 5, 2007 | 02:01 AM
kdsmppt's Avatar
kdsmppt
is it a new install? if so you may have ur subs wired 2ohm and ur amp isent stable at 2ohm and olny 4ohm. so ya you would wire ur sub 4ohm which suck compared to 2ohm
Old Dec 6, 2007 | 04:22 PM
95 gustang's Avatar
95 gustang
i have had it hooked up for a while. I think it has something to do with the ground wire, everytime the fuse blows there is a spark from the ground wire right near the screw. the screw was loose, im guessing this is the problem but i dont know how to fix it
Old Dec 6, 2007 | 10:13 PM
mrdeep2001's Avatar
mrdeep2001
try to tighten the screw? if you can swap the screw out for a bolt and nut because the screw can back out over time and get loose.
Old Dec 7, 2007 | 02:28 AM
seight311's Avatar
seight311
My .02
1. Theres a short in your power wire at some point, could have rubbed on just about anything and be repeatedly shorting out and popping your fuse.
2. Your amp is smoked. Were you beating on the system just prior to this happening?
Old Dec 7, 2007 | 03:57 PM
ttocs's Avatar
ttocs
if your ground is loose then that is your problem. Follow the sparks........
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 2, 2015 04:12 PM
