07 with sony head unit problem
Old Dec 11, 2007 | 03:35 PM
DocVenture's Avatar
DocVenture
Default 07 with sony head unit problem
WheneverI start the car I have to turn on the head unit. It won't stay on. Its getting really annoying. I had this unit in another 07 before I wrecked it and had no problems. Any idea's? The only difference is that this car has the subs in the doors, and I'm running Sirius with it.
Old Dec 11, 2007 | 06:08 PM
silver2006's Avatar
silver2006
Default RE: 07 with sony head unit problem
doesthe radioturn off or does just the sound go off? if the radio is staying on but no sound i would guess your speakers are wire wrong and they are loading down the radio. check and make sure you have the right wiring harnesses the shaker 500. then check all your connections.
Old Dec 12, 2007 | 08:56 AM
DocVenture's Avatar
DocVenture
The radio turns off. The clock stays on and all the settings stay saved I just have to push power every time Istart it
Old Dec 12, 2007 | 03:00 PM
Dave5point0's Avatar
Dave5point0
Your headunit sucks
Old Dec 12, 2007 | 03:52 PM
DocVenture's Avatar
DocVenture
Gee Dave thanks that was helpful!
Old Dec 12, 2007 | 04:57 PM
silver2006's Avatar
silver2006
check the switched 12volt wire for a loose connection. this would wire going into the radio that turns on when you turn the key on(not the remote turn onto your amp).be sure to check the inline fuse holder andfuse, for that wire, fordamage.if it all seems good, you mayhave to pull the radio and find away to see if it does itwhen its out of the car. if may have got damage in the wreck too.
cbird1177711
Sep 3, 2015 08:43 PM
Steve@CJPP
CJ Pony Parts
Sep 3, 2015 11:43 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
