should be easy question about nine.2 amp
Old Dec 23, 2007 | 05:29 PM
Emanpimpster's Avatar
Emanpimpster
Default should be easy question about nine.2 amp
I have a nine.2 amp hooked up to an 11Ov2 sub. On the side of the amp there is a switch for the high pass, and low pass and also none..I think. I have it on none right now. Would it bebetter sounding or better for my sub if i switch it to the low pass filter? Thanks for your help. Eric
Old Dec 23, 2007 | 07:29 PM
PReal's Avatar
PReal
Default RE: should be easy question about nine.2 amp
Should be set on low pass and the frequency should be at 200 hz or less.
Old Dec 23, 2007 | 11:59 PM
Emanpimpster
Preal im using the mach 460 hu so theres no way for me to adjust what frequency i send to the amp and im pretty sure i cant adjust frequency level on the amp itself its just hpf lpf or no filter at all. So should i still change it to low pass?
Old Dec 24, 2007 | 05:51 AM
EricM's Avatar
EricM
The dials for setting cutoff frequency should be on either side of the X-Over switch (LPF is on the left). I'd set it below 80 unless you like lots of muddy bass.
Old Dec 24, 2007 | 09:17 AM
Emanpimpster
Sweet I just did it. Thanks alot guys.
baddog671
Jul 26, 2016 01:20 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
