amp setup
Old Dec 28, 2007 | 05:03 PM
MrBill04's Avatar
MrBill04
Default amp setup
what should i set the component amp to High pass or full range.
Old Dec 29, 2007 | 10:19 AM
ttocs's Avatar
ttocs
Default RE: amp setup
what sounds best to you?
Old Dec 29, 2007 | 04:31 PM
MrBill04's Avatar
MrBill04
come on you amp gurus.......PReal, where you at??
Old Dec 29, 2007 | 04:58 PM
Abom's Avatar
Abom
Full Range. I assume your components have a mid driver... if you set to high pass you won't get enough of the lower end frequencies for your mid driver to sound good. Does your head unit have filter settings ? That will let you go a step further and fine tune what frequency the head unit cuts off at when sending your sound to the amp.
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
