PLZ help me with a sound system swap
hello mustang fan's!!!!!!!!!!
I U LOVE YOUR MUSTANG AS MUCH AS I DO, HELP ME ON THIS ONE GUYS & GALS
I really needyour help on this one, thanks to an old lady that totalled my beloved 95 'stang i ended up trying to get another one, i got luck and i got a really clean one,BUT THIS ONE DOESN'T HAVE THE MACH460 system that i had on my previous car, ican save thewhole system for sure but i don't know exactly what should i swapi would try to keep the amps (1 inside the center console and 2 on the trunk, the 4 speakers and the side tweeters i assume) but how do i do the dismount and then put all together working on mynew stang? plus this timeI may try to add a subwoofer. The only upgrade to the original system is a newAlpine Headunit
I NEED SOME DIAGRAMS if anyone has them, cheers and....
THANKS IN ADVANCE
Diego
THANKS IN ADVANCE
Diego
it's ugnna be a lot of work, I think. 'specially trying to get those wires out. Ford has a way of putting in wires where they'll never come out... but it's transversely true that you need those wires 'cause nothing else will fit. so i'd assume it's gunna be a lot of work and a lot of cussing.
it is not that bad. You will need the door panels from the mach system as well as the tweeter pods. The hardest thing to get out is the center amp and the wire hrns but they are not that bad. Or you can always scavenge parts from mine collecting dust in the closet.......
