Problem with front door speakers
Old Jan 5, 2008 | 10:23 AM
jlb8434's Avatar
jlb8434
Default Problem with front door speakers
I have a question for you experts out there, b/c i just can't figure it out. My friend and I installed a amp and two 10's in my 06 GT yesterday, after everything was hooked up, i was messing with the radio resetting it after the battary was disconected. Well i moved the fader all the way to the left sounded great, moved it all the way to the right and now nothingis coming out of any of the cars factory speakers, not the front or the back. Is there a fuse on the back of the radio for just one side or something that may have blown? any help would be greatly apperiacted.
Joe
Old Jan 5, 2008 | 07:48 PM
ttocs's Avatar
ttocs
Default RE: Problem with front door speakers
uh no, no fuses will cause this problem. Where did you get the signal for the amp? What other equipment is in the car? How competant is this "friend" in car audio wiring[:-]?????
Old Jan 6, 2008 | 09:07 AM
jlb8434's Avatar
jlb8434
I have the Shaker 500 system and that was it, I went to Ciruit City andtaked tothe audio guys.I used the audio inputs from the amp and pulled the signal out of the rear speakers, it's just stranger that one side works fine but the other doesn't work at all unless it's faded on that side and the volume is all the way up
Old Jan 6, 2008 | 04:13 PM
mr_spider3's Avatar
mr_spider3
is the amp powering up?
Old Jan 6, 2008 | 06:55 PM
jlb8434's Avatar
jlb8434
Theamp for the subs is, but i'm not sure about the one for the door, and would that stop the rear speaker from working also ( if the door amp is out).
Old Jan 6, 2008 | 09:18 PM
ttocs's Avatar
ttocs
sounds like they messed up a connection somewhere..... If you paid for the install take it back and they will be happy to help ya. Most places would rather fix their mistakes then to see you get in and possibly do more damage.
Old Jan 6, 2008 | 11:09 PM
jlb8434's Avatar
jlb8434
No i went to talk to them about the install, but i did it myself, like i said though the whole left sides works great but i don't get anything from the right side front or rear speakers.
Old Jan 7, 2008 | 01:58 PM
ttocs's Avatar
ttocs
how did you make your connections for the signal?
panic
Aug 28, 2015 02:37 AM
kdryan
Aug 26, 2015 05:54 AM
Tyoung68
Aug 25, 2015 04:31 AM
inyadreems
Aug 21, 2015 09:10 AM
69FB
Aug 18, 2015 08:50 PM
