Anyone have specs for building sub box for 07 Mustang
#21
RE: Anyone have specs for building sub box for 07 Mustang
ORIGINAL: ScottXL
seight311, ttocs, I've known you guys to be good people. But you guys are being straight d**ks right now.
So one big box will not fit? I bet two smaller boxes would? Now where on gods green earth could you get a design for a box that would fit one of those subs you have(each) so you could load two boxes in your car, screw them together and then mount your speakers in the box(s).
#22
Why would you build two seperate boxes and screw them together. That is the dumbest idea I have ever heard of.[sm=boosign.gif]
#23
Why can't we be friends???
LuckyDawg,
When you have two subwoofers, it's best to have them in separate chambers. Helps with your sound quality, and in case one sub goes bad, you can continue to use the box while you get a replacement.
There is no optimum size box for the subwoofers. Different boxes will produce different sound, that's why they give you a range to choose from. The smaller boxes will produce a better quality sound. As you go larger, sound quality decreases, but it gets louder. It's really a compromise you have to find.
I would recommend, since you have two subs, to go with the smaller size. You'll have plenty of bass anyways, the quality will be better, and you'll have some space left in your trunk.
In essense you will be building two separate boxes, joined together at the hip. It's one big box with a total of 1.6cft with an airtight divider in the middle, spliting it into two separate .8cft boxes.
Hope that helps you...
LuckyDawg,
#24
ok, thats it, AFTER THISI am done with this post. I didn't know you could stack shtuff this high but this now has my nomination for the stupidest post of the year(i know it is early in the year but it has a chance).
lucky dawg, lean in real close so that I know you are listening. Can you hear me now?
If that is a dumb idea to you then what do you have to put on the table? One box to fit 2 12's is generally too big to fit into the hole of the trunk. BUT, 2 smaller boxes will fit. put the boxes in the car, screw them together, and then insert the woofers and if you do a good enough job building the box and putting them together you will not notice. This also adds a bit of security since the box cannot be taken out of the trunk in one piece. I have done this on a couple of buddy's cars to get by the small opening.
DIE POST DIE!!!!
DIE POST DIE!!!!
ORIGINAL: luckydawg003
#25
Lol don't get all butt hurt ttocs, you sound like a dam baby. So anyways I am sure I can build a dual 10' box and fit it in the trunk. I just don't know how I can fit it in the very rear of the trunk. My car has sort of a ramp going from 2/3rds the way up the trunk and it has some big metal bar on the top going across the entire trunk length. So if I have to get past that the box is going to be very wierd shaped, it can't just be a square box.
#26
Grow up, spend thousands and thousands of dollars over several years time, learn a ton of information on your own, blowing things up, installing things backwards, and buying junk equipment. Then come back in here in 5 years andspend your time being nice tryingto help someone being a little ***** like you.
You will not get the help your looking for with your attitude, and do not insult someone who is very experienced and also very helpful to you. You are clearly what, 17 years old. Stop trying to whine and cry to us like you were to your parents about getting you a new Mustang for aMemorial Day present. Just have it shipped up to Unique and have them "trick" it out for you, then you won't have to worry about the math or logic behind anything we try and help you with.
#28
How do I build a box to fit on that upward angle? Can I build a triangle shaped box?
I like these boxes, Do you guys think it would be hard to guess the box dimensions and just build it however.
#29
Seriously, this thread was the biggest waste of time I have ever read.
Here, buy this and be done with it: http://cgi.ebay.com/ebaymotors/Ford-...2em118Q2el1247
Has the front look you are going for minus the fiberglass. Ask the guy to make it for your two 10"s.
I'm going to go try to learn something somewhere else.
