Battery Saver?
Old Jan 18, 2008 | 11:02 AM
ScottXL's Avatar
ScottXL
Default Battery Saver?
I was on Autozone looking for a replacement Battery, and I ran into this:
Link
What is this?
I googled 'Battery Saver Relay' and it came up with a bunch of stuff on how after your battery reaches X amount of charge with out the car being on, the relay switches on and stops the flow so your battery doesn't die.
But, this doesn't seem like it'd do that? Any idea on what it does do? Thanks in advanced.
Old Jan 18, 2008 | 01:40 PM
ttocs's Avatar
ttocs
Default RE: Battery Saver?
if you were looking for a battery and found a timing chain cover then you were in the wrong isle
By disconnecting the vehicle from the battery you will have a little longer life out of it. There is a minimal current drian on a battery to keep the memory in your radio for example. If you were going to store it for a long time(months) then I would recommend a slow trickle charger but they are normally less then $20.
Old Jan 18, 2008 | 02:42 PM
seight311's Avatar
seight311
Haha, it's a timing chain cover.
I read your post before I clicked the link, I was like I don't get that, is he making a joke???
Old Jan 18, 2008 | 03:01 PM
ScottXL's Avatar
ScottXL
I was actually online when I found it.
But what does it do?
'cause, I'd like a fail-safe incase I leave my lights on or something so the battery doesn't die and I'm f***ked.
Old Jan 18, 2008 | 08:22 PM
ttocs's Avatar
ttocs
it plugs into the wall an then provides a trickle charge to keep the battery up. If you were to leave your lights on I do not know that it would provide that much current to drive the lights although it would probably make it easier to plug the charger in.
again these are made for when you are going to store the car for months, not over night.
Old Jan 19, 2008 | 01:45 AM
ScottXL's Avatar
ScottXL
Err... that's a different product than before.
http://www.autozone.com/R,APP757982/...ductDetail.htm
Let's hope that link works?
Anyway, it doesn't really look like it plgus into the wall. I don't know where it plugs into. But, if it's just for cars sitting for a long time, then nevermind. Thanks for the help.
Old Jan 20, 2008 | 06:34 PM
ttocs's Avatar
ttocs
I have not clue what that is. It looks like the large gauge termianal that tow trucks haveon thefront of their trucks to easily connectjumper cables to jump other cars.
Now just curious does your say GP by SORENSEN across you pic as well?
Old Jan 20, 2008 | 06:38 PM
ScottXL's Avatar
ScottXL
Yeah... >_>
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
