Mach 460 Aftermarket Headunit
Old Jan 30, 2008 | 07:09 PM
Kioso's Avatar
Kioso
Default Mach 460 Aftermarket Headunit
I have a 2000 mustang and it has the mach 460 audio system.
I want to put in a different headunit, I know I need something like the Scosche FD03B but what other harness do I need? The FD03B only does the RCA outputs to the stock amp.
The stock unit is split into two different sections. One has my CD player and the other has a tape player, what type of install kit would I use for this set up. The one I was looking at walmart has a one piece, but I need a two piece.
Old Feb 1, 2008 | 01:26 PM
Kioso's Avatar
Kioso
Default RE: Mach 460 Aftermarket Headunit
I found the harness I need, but I still don't know what dash install kit I need.
Harness -
http://www.partsexpress.com/pe/pshow...TOKEN=18596817
I've been looking and I can only find two install kits and one that will work
http://www.partsexpress.com/pe/showd...number=265-805
The problem with this install kit is that I have a two section head unit stock. The first one like I said in my first post that the top is a tape player and the second is a CD player, I need to have both sections removed and I need an install kit that will make a empty panel where one of the sections was.
Thanks!
Old Feb 1, 2008 | 07:48 PM
ttocs's Avatar
ttocs
if you have the split dash(tape on top, cd on bottom) you don't need a kit. The decks cage will slide inplace and you can get a universal din pocket to fill the other space.
What kind of deck did you get, and does it have subwoofer outputs?
Old Feb 5, 2008 | 02:06 AM
007Bullet's Avatar
007Bullet
Old Feb 5, 2008 | 05:53 AM
apolnerow08's Avatar
apolnerow08
ttocs are you sure about that? most kits that take up the double din setup have a space that becomes just a little spot to like put CD's and you need that kit. I dont know of any head units that fit the stock bracket
Old Feb 5, 2008 | 10:40 AM
ttocs's Avatar
ttocs
nope[:-], not very sure at all, no sir, been driving for 3 WHOLE days now[X(]! And been installing for 2 of those days!!!!
I like pizza!! I got a wallet!
welcome to the forum, please feel free to chime in when you are sure of the info you are giving
Old Feb 9, 2008 | 12:37 AM
Kioso's Avatar
Kioso
Umm I'm confused. I don't understand what you mean. And I don't know what I need to do now..
Thanks [&o]
Old Feb 9, 2008 | 10:29 AM
ttocs's Avatar
ttocs
right well you didn't answer my questions above[:-]?
ORIGINAL: Kioso
Thanks [&o]
Old Feb 10, 2008 | 06:46 PM
Kioso's Avatar
Kioso
its a sony headunits and has two rca outputs on the back
Old Feb 10, 2008 | 07:16 PM
apolnerow08
The Sony headunit will take the place of the tape deck on the top and then this.. http://www.crutchfield.com/App/Produ...50&tp=1114..will take the place of the cd player on the bottom. And then to connect the factory wires to the Sony headunit you need these.. http://www.crutchfield.com/App/Produ...002&tp=736
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 24, 2015 09:18 PM
