Rear speakers
Old Feb 2, 2008 | 12:29 AM
apolnerow08's Avatar
apolnerow08
Default Rear speakers
Anyone know how to take off the rear dash so I can get the the front of the speakers? And if I take off the Mach 460 amp rack can I get to the bottom of them? Got an '04
Old Feb 2, 2008 | 01:22 AM
ttocs's Avatar
ttocs
Default RE: Rear speakers
what are you wanting to do? The rear enclosure that houses the speakers is not accesable from the top. You will need to remove the amps from the bottom of the enclosure, and then remove the screws the cover. The woofer is an 8 ohm woofer so it does not work well with the standard 4 ohm speaker, the mid is 4 ohms but only 3.5"s.
Old Feb 2, 2008 | 10:50 AM
apolnerow08
I know I cant do anything to the speakers from the top, thats how most speakers are in the rear. And do you mean the 6x8 or 5x7 speakers in the back as woofers and the component tweeters are 3.5"? Someone before I had the car hooked up speaker wires for another amp I guess but I dont know what he did because theres 4 wires and it looks like only two have been used, plus theres a loose connection to one of the speakers Id like to fix
Old Feb 2, 2008 | 12:10 PM
ttocs's Avatar
ttocs
if you did not have the mach system the speakers would have been top loaded meaning you would have had to pull EVERYTHING out of the back of the car before removing the package tray cover, that covers the speakers. alot of cars have their speaker top loaded. They install them before they putin the back window.
Can you take a pic of the wires?
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
Doogie65
Sep 6, 2015 02:55 PM
