Mach Door Speaker HELP!
Old Feb 24, 2008 | 11:29 AM
kingburna's Avatar
kingburna
Default Mach Door Speaker HELP!
I have a '96 GT with the Mach 460 speakers. All the speakers work except for the 2 door speakers.
Anyone have a guess or fix as to y the door speakers don't work? Help me please...
I have a Kenwood KDC-mp5032 cd player and two pioneer twelves n the trunk. I didnt do the install, i bought the car used w/ everything.
Old Feb 25, 2008 | 04:27 PM
ttocs's Avatar
ttocs
Default RE: Mach Door Speaker HELP!
the front woofers run of a seperate amp from the rear, could be a blown fuse so I would start simple and look there. No, niether I nor anyone else knows which fuse to check and I am not going to read your manual. It sounds tedious but it honestly takes less time to pull EVERU fuse and check it then it does to get out your manual, figure out which section/page, which circuit you think it may be, where that fuse is located, ect. Check EVERY fuse both under the dash as well as by the battery.
You could also have a blown set of woofers.........
Old Feb 27, 2008 | 06:05 PM
buster05's Avatar
buster05
hey man im having the same trouble. let me know if you get them fixed
Old Feb 28, 2008 | 11:13 AM
Unforgivine's Avatar
Unforgivine
i might have 2 blown speakers or you can just rewiring them to your cd player
Old Feb 28, 2008 | 04:57 PM
Mustang Nation's Avatar
Mustang Nation
Maybe they got lazy on the install and never rewired the front speakers to the New radio pull em out and see if its hooked up or to the factory wiring good luck.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
