Question about tunning an amp????
ok thanks, the sub came with the box i bought, so i belive it was made the box was made for that sub
u guys are awesome, i cant wait to go test it out.
was that english?
I would look into getting something like this
http://www.edesignaudio.com/product_...products_id=31
That's the 13Kv.2 by Elemental Designs. I don't know the size of the enclosure that you have, but if it is around 1 cu ft you can drop this right in and be set. If the rough dimensions of the sub box internally is 12 x 12 x 12 you are good to go.
If not, i would buy some MDF and build a box. It is a lot easier than you think, and only will cost you about $20. Your home built box and sub will cost $80 less than what you paid for that scosche and be ten times better. As long as you have some mechanical skills.
your amp only puts out a claimed 300W @ 4 ohm and 500W @ 2 ohm. This sub will take all of that and maybe a little more. I would not turn the gain up alll the way on that amp though because i am pretty sure it will clip it.
This would workwith the300 you gotand get quite loud at the same time.
http://www.ddaudio.com/dd/caraudio/w...asp?series=500
i would like to buy the best sub possible for this amp
http://www.cartronixplus.com/templat...20ALL%20%3E%20
and this sub box
http://www.crutchfield.com/S-G3pvoLS...x?I=142FDMUS05
and this sub box
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
