Question about tunning an amp????
Old Feb 26, 2008 | 04:28 PM
PennState's Avatar
PennState
Default Question about tunning an amp????
So my subs used to sound good till bestbuy messed with the amp...theres three categories
1) Base boost that goes 0-18
2) lpf frequency that goes 50-200
3) input sensitivity (v) that goes min 5 to max 0.2
i have a 1000 watt amp with a 1000 watt sub i think
how would i set each of these dials, please help..thanks
the amp i have
http://images.kenwood.eu/files/produ.../KAC-8103D.jpg
Old Feb 26, 2008 | 05:09 PM
seight311's Avatar
seight311
Default RE: Question about tunning an amp????
What subwoofer do you have and what kind of enclosure is it in?
Old Feb 26, 2008 | 07:13 PM
PennState's Avatar
PennState
got this exact sub and box...
http://www.crutchfield.com/S-Dd92jai...x?I=142FDMUS05
Old Feb 26, 2008 | 08:16 PM
luckydawg003's Avatar
luckydawg003
Ya that amp is only 300 watts rms-thats the continous power it puts out. 900 watts peak power. I would probably set the bass boost to 10, lpf to 50 hz, gain to about half way maybe 3/4 way.
Old Feb 26, 2008 | 08:32 PM
Iskwezm's Avatar
Iskwezm
ORIGINAL: luckydawg003
I would probably set thelpf to 50 hz,
50 Hz is too low, 70 or 100 would sound better imo.
Old Feb 26, 2008 | 08:55 PM
PennState's Avatar
PennState
u guys are awesome
tommroow imma try and mess with it
imma try 70hz
Old Feb 26, 2008 | 10:40 PM
PennState's Avatar
PennState
hey guys i just went out and tried eveything u guys said but when i turned the gain up to .75 the subs hit really harrd and not really clean, how can i fix that..any other recommendations.
Old Feb 27, 2008 | 12:29 AM
seight311's Avatar
seight311
You are a retard.
Set your bass boost to 0
Set your LPF to 100-115
Set your gain to roughly 3/4, give or take. Do this setting with a cd playing at a high but comfortable listening volume, the loudness you would have it if you were cruising down the highway to song you like pretty loud, turn it up until the subwoofer starts making a not so smooth noise, (slight distortion, then back it off a tad)
Old Feb 27, 2008 | 10:19 AM
Iskwezm's Avatar
Iskwezm
ORIGINAL: seight311
You are a retard.
I agree
turn the bass boost down, i never turn mine up.It over boost the signal and gives it a muddy sound.
Old Feb 27, 2008 | 10:52 AM
cegha's Avatar
cegha
ORIGINAL: seight311
You are a retard.
I agree, turn bass boost to 0 and never touch it again. Bass boost is a devil created by amp manufacuters. It serves no useful purpose. Turn it to 0 and i would reccommend setting your gain (input sensitivity as it's called on your amp), with a DMM. If you do not have a dmm then just set it by sound. Put on a cd on a normal listening volume that you usually listen to and adjust the gain until it distorts then back off some.
See bass boost amplifies the signal a lot, and in doing so causes a distorted signal to be sent to your subwoofer causing it to receive a clipped signal. If you look at a sine wave, like when setting with a o-scope, you ideally want a perfect sine wave. When you send a clipped signal to your subwoofer it will fry it very quickly and it is also not good for the amp either.
Also i honestly wouldn't be expecting a ton of output if your only running 300rms to a sub. Sure it's going to have some bump, butit's not going to be a lot unless you have a very efficient box built for it.
