Mach door tweeters install
Old Mar 5, 2008 | 08:41 PM
wolverine_mx's Avatar
wolverine_mx
Default Mach door tweeters install
I had the stock audio system a year ago, I replaced all with a dvd/tv/usb/sd card reader, amp, subs, speakersand re-wired all...
when trying to install door tweeters, I realized that Mach systems came with so i got a pair of tweeters from ebay. but while installing I found the door covers will not fit so I need to cut them... do you guys know how much to cut or have any layout??? anyways I'll try to fit while cutting.
Old Mar 6, 2008 | 01:56 AM
ttocs's Avatar
ttocs
Default RE: Mach door tweeters install
it is more then just a cut, it is a different shape on top. It will be difficult to try and make your panels look good with the covering that is on the panel in that section. It will be more pain then it is worth to be honest because while the sail panels raise the soundstage, it can also ruin the soundstage if it is not done right. The drives tweet becomes the closest speaker to you and pulls everything over there.
What are you powering them with? It will really be either lot of money for new panels, or alot of work to make it look good for factory speakers.
Old Mar 9, 2008 | 02:03 PM
wolverine_mx
well first of all I got both tweeters (speakers)including their whole base (not just the lil speakers), so at the door, after removing the lil plastic triangle and fitting the mach speaker's panel I realized that the door panel will not fit so a small cut will make the job or that's what I think. that was the reason about this thread, to hear what do you think about.
btw, the wires are both set already. I ran 'em from the head unit (I had the 2 front speakersoutputs free)
Old Mar 9, 2008 | 06:43 PM
ttocs's Avatar
ttocs
good luck then. got any pics?
Old Mar 11, 2008 | 04:46 AM
wolverine_mx
Not yet... have been busy all these days, I'll give it a shot this thursday...
Old Mar 13, 2008 | 12:04 AM
TKS98GT's Avatar
TKS98GT
Hey, where do the speakers hook up on the head unit?? the wire harness or the unit its self?? because im just running the stock tweeters straight to my replacement front speakers...and the sound is clear..just kind of "jimmy" rigged..lol
Old Mar 13, 2008 | 01:18 AM
ttocs's Avatar
ttocs
they should be hooked up to their own output from the deck. You will have to run wire through the boot, into the car and the deck. If you hooked it up the same speaker wire that powers the 5 x7 you will notice your deck will start to run hotter, and will probably shut off or at least it will hopefull shut off before it melts.......
Old Mar 13, 2008 | 10:22 PM
TKS98GT's Avatar
TKS98GT
so i should take them off the speakers??
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
