problems with system again
Old Apr 6, 2005 | 10:56 AM
bizarre660's Avatar
bizarre660
Default problems with system again
i finally got the subs to work but of course got a minor problem, or maybe not. does any one elses system pull off some power even when the car is off. like if i take the power cord and just touch the battery the wire sparks. is there a way to fix this. like a relay or something? thanks.
Old Apr 6, 2005 | 03:08 PM
Shawn02GT's Avatar
Shawn02GT
Default RE: problems with system again
the 12V line to the battery will always have juice, its the remote turn-on wire that turns the amp on.
Old Apr 6, 2005 | 06:54 PM
dc_mann8's Avatar
dc_mann8
why would you be touching the wire to the post.. it should be bolted on there and not taken off with a fuse in the line..? i dont get it
Old Apr 6, 2005 | 06:57 PM
Choppa's Avatar
Choppa
its suppoesed to do that
Old Apr 7, 2005 | 01:00 AM
98stngfrk's Avatar
98stngfrk
bizarre, had a bizarr question, I know, I know corny, but I am tired and just felt like posting something. But like everyone else said yes it should do that since it is your POWER wire, so i think this thread is over with.
Old Apr 7, 2005 | 01:17 AM
bizarre660's Avatar
bizarre660
like when i put the power line onto the battery it sparked. and when i put the ground wire into the amp another time putting the box in it sparked to. does anyone ever hear of putting a relay or something on it?
Old Apr 7, 2005 | 01:18 AM
bizarre660's Avatar
bizarre660
yea 98 stank thanks for the useless help.
Old Apr 7, 2005 | 01:44 AM
dc_mann8's Avatar
dc_mann8
ORIGINAL: bizarre660
thats very normal. you should always disconnect the ground terminal off of the battery when working on anything eletctrical!
you have no problems with the system.. sparks are sometimes a good sign. hope it helps, any more questions just ask
Old Apr 7, 2005 | 11:28 AM
rednblackdawg's Avatar
rednblackdawg
Yes it is normal. The spark you see is the circuit being completed when you touch the wire to the post. No power is being used though as long as the system is off. You could take the power wire from the headlights and disconnect it and then touch it to the battery terminal without the headlights being on and it too would spark.
Old Apr 8, 2005 | 01:13 AM
bizarre660's Avatar
bizarre660
aight cool thanks guys. i just was wondering if it was pulling from my battery becasue i had it on another car that i have that usually sat around like threw the winter and something would drain the battery and i thought it was this damn thing.
