What are the Dimensions?
Old Mar 8, 2008 | 02:35 PM
wilburgtwoot's Avatar
wilburgtwoot
Default What are the Dimensions?
I would really like to put some 12" subwoofers in my trunk. I drive a 1999 Mustang Gt Coupe. Trunk space is very limited, but I'm trying to figure out how much room I would have to work with if I disconnected my backseat and slid a box in through the back of the trunk. The speaker rack will be removed from the rear as well, so I won't be as restricted with the height of the box. Anybody had any luck fitting 12" subs in a mustang coupe?
Old Mar 8, 2008 | 07:25 PM
ttocs's Avatar
ttocs
Default RE: What are the Dimensions?
you will be limited on the height if you try and load it from the front. I builta box for a buddy and a single 12", and we had to remove the weather stripping on the trunk to get it in(you are limited to 13" height both to get under the rear deck and to fit it in if I remember correctly). If I had built a box for 2 - 12's it would not have fit, but I could have built a 2nd box for a single 12 and put it next to the other.
Old Mar 8, 2008 | 09:59 PM
slimshorti1589's Avatar
slimshorti1589
i have two 12 subs in mine although i dont have the amp rack that comes with the mach system.....all you have to do is angle the box a little bit...
Old Mar 9, 2008 | 01:23 PM
wilburgtwoot
ORIGINAL: slimshorti1589
What type of box do you have exactly, sealed or vented? Also, are any of the sides of the box angled in anyway? Last thing, where did you put the box in from, the rear or the front?
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
my96mustang
Aug 24, 2015 06:12 AM
Grandmaster
Mar 20, 2006 08:43 PM
Coli23
Dec 4, 2005 06:12 PM
