Where to install line driver
Old Mar 13, 2008 | 05:48 PM
chilledfresh's Avatar
chilledfresh
Default Where to install line driver
I picked up a small TLD-22 line driver from Phoenix Gold, and was wondering where I should install it. Also, do I tap power for the line driver from the head unit's harness cables?
Help me, I'm a noob! [8D]
Old Mar 13, 2008 | 06:26 PM
ttocs's Avatar
ttocs
Default RE: Where to install line driver
you want it as close to your source as possible to keep from amplifying noise that it has picked up prior to the line driver. You should be fine hooking it up to the same source as the deck. Let me know if you blow a fuse with it on and we can fix that.
Old Mar 18, 2008 | 06:49 PM
JBster's Avatar
JBster
I put mine under the passenger seat. Doesn't get any feeback at all.
As for power, I actualy tapped the power from the buttons on the lower dash under the radio - floor lights, traction control, and defogger. I have a few different things hooked up to those, and they seem to be a great source of power. I have not blown a single fuse yet.
Old Mar 18, 2008 | 11:01 PM
ttocs's Avatar
ttocs
yet, YET.................
Old Mar 19, 2008 | 05:42 PM
TI302's Avatar
TI302
tap into your ignition or remote wire, mount it near your deck. line drivers are great for the 8volt signal, but do you know if your amp will take an 8 volt signal? a lot of amps cut out above 5 volts.
Old Mar 20, 2008 | 11:20 AM
JBster's Avatar
JBster
yet meaning over a year...
Old Mar 20, 2008 | 11:58 AM
ttocs's Avatar
ttocs
yet meaning keep adding things to those circuits.
double dog dare ya...
If you have too many things and you are worried about overloading a circuit, then let us know and we can show you how to properly use a relay to fix this.
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
SYNY5TER
Sep 2, 2015 01:35 AM
Hillbilly1968
Aug 19, 2015 12:03 PM
