Need Audio Input/Suggestion/Help
Old Mar 15, 2008 | 08:24 PM
Aereon's Avatar
Aereon
Default Need Audio Input/Suggestion/Help
Hey guys, I'm wanting to get a light weight subwoofer that wont take up too much space in the trunk. I am looking for a setup similar to the mach1000 sub or the shaker sub that goes in the corner of the trunk. I will be shoving this in on the driver side as the passenger side will house the battery relocation box I'll be fabbing up soon.
I am just looking for something that will deepen my bass a bit. Here is the setup I will be buying for the other speakers in the car.
I think I'll be going with the Hifonics CRUNCH P900.4 for the amp. 4 chan 115w nom
And I'm also looking into buying 2 Hifonics ZXi6.5c comp set for the rear deck tweet/speaker and door tweet/speaker.
I really only want to spend about 300-400 tops for everything. I am actually semi happy with the stock speakers but I want a bit deeper bass and a set of cleaner/crisper tweets. I'll most likely cut a piece of wood to house the 6.5 in the 5x7 spaces or find some good adapter plates.
Any input is welcomed as I'm a very big audio nub.
Here is the specs for the speakers:
* SPECIFICATIONS
o 6.5" Coaxial Component
o MAxx Power : 500W
o Nominal Power : 2 - 100W
o Impedance : 4 ohm
o Frequency Response : 60Hz - 30kHz
o Sensitivity/SPL : 91dB
o Mounting Depth : 2.44"
Here is the specs for the amp:
* SPECIFICATIONS
o Amplifier Class : N/A
o Number of Channels : 4-Channel
o Maximum Power : 900 Watts
o RMS Power Output @ 4 Ohms : 115 Watts x 4-Channel
o RMS Power Output @ 2 Ohms : 225 Watts x 4-Channel
o Bridged Power : 450 Watts x 2-Channel
o THD : 0.05%
o Signal-to-Noise Ratio (dB) : 90dB
o Frequency Response (Hz) : 30Hz~1.2kHz
o Built-in Crossover : Yes
o High-Pass Crossover Frequency : 60Hz~1.2kHz
o Low-Pass Crossover Frequency : 30Hz~250Hz
o Bass Boost : 0dB~12dB
o Bass Remote : N/A
o Fan Cooled : N/A
o Fuse Rating : 20A x 2
o Dimensions (Width x Height x Length) Inches : 10" x 2.16" x 11.81"
o Approximate Weight : 8.1 LBS
o Warranty Information : 1 Year Warranty
Old Mar 16, 2008 | 12:31 AM
Aereon's Avatar
Aereon
Default RE: Need Audio Input/Suggestion/Help
since there wasnt any responses I'm thinking about these now, any thoughts/opinions, will I need a seperate amp for the sub? if so what would you recommend?
Again I'm looking for the best system I can get for around 400-500
Kicker (8 or 10") cvt subwoofer http://www.nextag.com/Kicker-Comp-VT...02/prices-html
Hifonics ZXI 4408 4 channel - RMS - 55 http://www.maxxsonics.com/hifonics/amps_zeus.html
Hifonics ZXI 683 5x7 speakers 3 way RMS 30-85 http://www.maxxsonics.com/hifonics/speakers_zeus.html
Old Mar 16, 2008 | 11:43 AM
PReal's Avatar
PReal
I personally wouldn't be looking at any of that equipment with the exception of maybe the amp.
What is your budget?
What type of music do you listen to?
Do you already have an aftermarket HU?
Old Mar 16, 2008 | 04:22 PM
Aereon's Avatar
Aereon
ORIGINAL: PReal
Budget: 400-500 (would like to keep it under 400)
Hu: Pioneer Avic Z1 (with a 10 gig z2 hd)
I'm really not looking for anything too fancy I'd just like a cleaner sound coming out of my stereo. I'd also like to get a sub that fits in the driver's side corner of the trunk(I don't want to take up too much trunk space).
Old Mar 16, 2008 | 06:27 PM
seight311's Avatar
seight311
You said lightweight but your on a budget so not too much is going to be heavy regardless.
Cant get much smaller than this...
http://www.edesignaudio.com/product_...roducts_id=106
http://www.woofersetc.com/index.cfm?...roduct_ID=6027
http://www.woofersetc.com/index.cfm?...roduct_ID=5308Stock looking even.
http://www.edesignaudio.com/product_...products_id=45
http://www.ikesound.com/product-product_id/2212Super cheap, but will get the job done.
http://www.edesignaudio.com/product_...roducts_id=289Tell them you want the tuning up'd a little bit.
Old Mar 17, 2008 | 09:48 AM
PReal's Avatar
PReal
For $400....
Comps - http://www.woofersetc.com/index.cfm?...roduct_ID=4596$170
Comp Amp - http://ikesound.com/product-product_id/2839$55
Sub - http://www.edesignaudio.com/product_...roducts_id=106$70 (If you need really really small)
http://www.edesignaudio.com/product_...products_id=30$90 (Can be placed insmall box but you need more depth)
Sub Amp - http://ikesound.com/product-product_id/2840$70
A wal mart wiring kit for $20 would also be just fine.
That totals out to less then $400 without box construction supplies, but that will only cost you $20.
Old Mar 17, 2008 | 02:47 PM
Aereon's Avatar
Aereon
ORIGINAL: PReal
For $400....
Thanks for the reply, that sounds pretty good, only question I have is that a lot of people I talk to tell me not to go with a profile amp. I really like their prices but it seems like they might be comparable to the crap amp I have right now? (pyle amp)
Old Mar 17, 2008 | 04:20 PM
seight311's Avatar
seight311
Profile amps do their rated power. They are perfect for anyone on a budget, they work just fine.
If I was, or when I do budget systems, the only amps I consider are Profile and TMA (Total Mobile Audio) But it's hard to find Total on the net anymore, Sonic had them for a while but they stopped carrying them.
Old Mar 17, 2008 | 05:03 PM
PReal's Avatar
PReal
ORIGINAL: Aereon
ORIGINAL: PReal
For $400....
Profile might be cheap but by no means are thier amps garbage. I have purchased two for budget installs for myself and installed them in numberous other cars. The one time I did have a problem I was repaired under warranty by only paying shipping charge and spoke to a very nice customer service rep that was actually in the us or spoke very clear english. All I did was send it to california.
I have had more problems with hifonics amps then I have with profile. I actually had a hifonics catch on fire while installing it. Beleive it or not, the amp had an internal short and as soon as it was connected to 12V + and - it built up a ton of heat and was smoking.
So far I am 1/5 on profile with problems and 1/4 on hifonics.
Old Mar 17, 2008 | 05:35 PM
Aereon's Avatar
Aereon
thanks=P thats all I needed to hear^^
