radio
Old Mar 18, 2008 | 06:53 PM
fast stang15's Avatar
fast stang15
Default radio
i took out my gauge cluster to fix my odometer gear. wen i put it all back together my radio turns on but i have no sound. it is turning on my amp but i am getting sound out of my subs but not out of my tweeters. and my amp is stayin on all the time. can anyone help
Old Mar 18, 2008 | 07:03 PM
fast stang15
Default RE: radio
i changed out my head unit and i still hav the problem. i unplugged the plug closest to the driver side for the front amp and im getting signal. im wondering if it could be the amp that is bad. is there a way i can bypass the amp and go directly to the speakers. if anyone has a good detailed wiring diagram i would appriciate it thanks.
Old Mar 18, 2008 | 10:57 PM
ttocs's Avatar
ttocs
Default RE: radio
we are gonna need a list of what equipment is in your car, factory or otherwise before we can tell you anything. Help us help you
Old Mar 19, 2008 | 07:04 AM
fast stang15
Default RE: radio
it has a after market head unit and amp for the rear. it is the mach 460. stock speakers. even with the stock head unit it did not work. hope this helps.
Old Mar 19, 2008 | 02:05 PM
ttocs's Avatar
ttocs
Default RE: radio
no that is still no help. It would be like giving me directions to your find your house, starting at the road with the lines in the middle, and the stop sign at the end..........
I need numbers mang, model numbers..... not the general size, shape or color but real #'s.
Old Mar 19, 2008 | 08:15 PM
fast stang15
Default RE: radio
hey ttoc i went 2 ur website on page 2 and the wire that you were pointin at where does it plug in at. i have the adapter from wall-mart that plugs in to factory hrn's.
Old Mar 19, 2008 | 11:26 PM
ttocs's Avatar
ttocs
Default RE: radio
in an sn95 style stang it is directly to the right of the radio, on a fox body it is behind the glove box. I still have no idea what you have to help you, good luck.
Old Mar 20, 2008 | 09:46 PM
fast stang15
Default RE: radio
i havea 1997 mustang.i know where the plug is but wat do i do with it. hope this helps
Old Mar 20, 2008 | 11:28 PM
ttocs's Avatar
ttocs
Default RE: radio
TAKE TWO........
ACTION!
ORIGINAL: ttocs
Old Mar 21, 2008 | 10:54 AM
fast stang15
Default RE: radio
i have the same setup that is in the picture of urs on your web site. all i know is the car is a 1997 mustang. mach460 stereo.
