radio
Old Mar 22, 2008 | 02:09 AM
ttocs's Avatar
ttocs
Default RE: radio
ok, I am half way able to help you, stick with me now.
What kind of amp and sub? How do you know the amp is turning on?
Old Mar 22, 2008 | 09:47 AM
fast stang15's Avatar
fast stang15
Default RE: radio
i have 2 kicker subs and a aftermarket amp. the light comes on that is how i know it's on. but that is not my problem, my tweeters are not workin. i pulled out the deck with the rear amps so that i could put in my box. before i replaced my head unit i got signal for my amp by using a plug that went to the amp. and it worked fine. hope this helps. thanks
Old Mar 22, 2008 | 02:28 PM
ttocs's Avatar
ttocs
Default RE: radio
so if I am reading this correctly, you have the stock speakers up front, but removed the amp that powers them? I think I found your problem.....
Old Mar 22, 2008 | 10:20 PM
fast stang15
Default RE: radio
no. they worked fine untill i messed with my gauge cluster. i only removed the 2 amps in the rear which power the speakers that are actually in the door. i'm not real worried about those i just want the speakers on top of the door (tweeters) 2 work.
Old Mar 23, 2008 | 02:39 PM
ttocs's Avatar
ttocs
Default RE: radio
the tweeters are driven by the amp/x-over that is under the radio. I really have no idea what you could have done around the gauges since I just had mine out of my 94 last week. The only thing I can think of that is audio related back there is that there is a really thick hrns behind the cluster that has every wire from door locks to speaker wires and you might have shorted it some how.
Is there something you are not telling me? Where there any problems in the install? Did you make any sparks?
Old Mar 23, 2008 | 09:26 PM
fast stang15
Default RE: radio
no there were no problems.i unhooked my battery wen i messed wit my gauges and wen i was finished i turned on the radio and there was no sound. i thought it was my head unit so i replaced it and i still have the problem. lets just say the front amp went out could that be the problem if so how can i bypass it and go directly from my headunit 2 the speakers.
Old Mar 26, 2008 | 06:21 PM
fast stang15
Default RE: radio
any more help plz
Old Mar 26, 2008 | 06:30 PM
ttocs's Avatar
ttocs
Default RE: radio
you can bypass the amp the way I show on page 2 of my cardomaing page.
Old Mar 26, 2008 | 07:42 PM
My Eleanor's Avatar
My Eleanor
Default RE: radio
you can run your own wires.. had a similar problem but i was replacing all the speakers anyways so it was slightly more work to just run my own stuff.
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
