Interior gear lighting
Old Mar 24, 2008 | 06:42 PM
KMS2889's Avatar
KMS2889
Default Interior gear lighting
I have a 2002 mustang gt with an auto transmission, i got a pioneer head unit that lights up blue and am planning on changing the gauges and a/c panel to blue and red. Does anyone know if it's possible to change the color of the gear indicator (P,R,N,D,1,2)? If so what do I need to get?
Old Mar 25, 2008 | 10:24 AM
richmustang1880's Avatar
richmustang1880
Default RE: Interior gear lighting
i changed the lights behind the ac panel had to take out the green plastic behind the guage a pain in the *** took like 15 min with a razor blade. i just changed the bulbs to red ones....bad idea actually started to melt the conectors and the bulbs faded cuz they got so hot ild recomend leds ill be putting mine them in the ac and the gauge cluster in the next few weeks as for the gear indicator i driveamanual so cant help you
Old Mar 25, 2008 | 10:31 AM
ttocs's Avatar
ttocs
I just swapped out my gauge lighting to blue bulbs. The panel is a cool blue at night but it is darker as well. It was not too bad as far as install, you have to take the cluster out, and seperate the clear plastic front, and then pull the gauges out to get to the bulbs. I don't think led's will work very well behind the gauges as they require a light with a non-directed light to properly light the gauges. I bet with led's in the gauges you will get 5 very bright spots, you would also loose the ability to dimm the dash as led's are either on,or off.
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 3, 2015 07:14 PM
amandahchase
Sep 3, 2015 10:09 AM
