help with 8 inch rockfords
Old Apr 3, 2008 | 01:14 AM
ttocs's Avatar
ttocs
Default RE: help with 8 inch rockfords
200 - 800 watt rms amp? ha ha ha what kind of recommendation is that man?
so he will want an amp between 400 - 1600 peak???
Its like going into a showroom and sayin it is between a v6 mustang and ford GT...
#3spof just because dopey is giving advice...
ttocshiss
Old Apr 3, 2008 | 07:29 AM
disturbed471985's Avatar
disturbed471985
200 to 800 wow thats a narrow range.
Old Apr 3, 2008 | 08:35 AM
07lane40's Avatar
07lane40
ORIGINAL: blue stang
I think he wants a stereo setup instead of a mono so he can have a left and right chanel.
why in the hell would you run subs stereo?
Old Apr 3, 2008 | 08:48 AM
PReal's Avatar
PReal
If your going to go mono run the subs parallel and do this:
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
after that get a 200 to800 watt RMS at 2 ohmsmono(1 channel) amp.
Please quit posting...
You are making it hard on people that actually understand how electronics work...
Old Apr 3, 2008 | 01:50 PM
blue stang's Avatar
blue stang
Wow!! you guys are bigger *** holes than I thought. the subs are rated 50 watts to 200 watts RMSwith a 400 watt peak. he has four of them, thus you get 200-800 watt RMSsafe zone with a max of 1600 watts. If you run your subs at 1600 watts they will burn. Anyone who has been in an electronics class should know this.
Old Apr 3, 2008 | 01:55 PM
07lane40's Avatar
07lane40
um. youre an idiot. and its not electronics, its physics.
Old Apr 3, 2008 | 01:59 PM
blue stang's Avatar
blue stang
ORIGINAL: 07lane40
in case you havnt seen the stereos in cars now days they have seperated the the components into a tweeter and a sub. they leve the subs in stereo to get that full 360 degree sound. that is why left/right and front/back are seperated at the head unit.granted it wont be as loud or perfect sounding, it will retain the 360 degree sound.
personaly I wouldn't go with a stereo set up eather because loud bass sounds from all directions anyways. I figured the thread starter wanted them in stereo since that is how he seid they are hoked up now.
Old Apr 3, 2008 | 02:04 PM
blue stang's Avatar
blue stang
ORIGINAL: 07lane40
HAHAHAHA! you do know that electronics is comprised of various parts of both physics and chemistry?
Old Apr 3, 2008 | 02:07 PM
PReal's Avatar
PReal
ORIGINAL: 07lane40
Actually its not a sub and a tweeter it is a midrange/woofer and a tweeter. No subwoofer plays frequencies to 2500hz. A midrange plays much moreof the frenquency range and should be in stereo. Also,low frequencies are considered omnidirection, thatis whyyou do not see twosubs in stereo in 99.999% of stereo installs.
Also in stereo sound you do not want 360 degree sound you want directional sound from the right and left channels hense the word stereo.The sound should however fill the volume of the room/car, but youdo not want to hear both speakers at 360 degress becuaseit defeats the purpose of stereo. For 360 degree sound you require some sort of multi channel sound staging with a lot more then just 2 speakers.
Once again, you are making this harder on everyone. Please give up.
Old Apr 3, 2008 | 02:09 PM
07lane40's Avatar
07lane40
no theyre seperated into tweeter and woofers. you do not have "subs" with tweeters. and In fact i have seen these stereos in cars today. i have a pretty nice one just in case you were wondering. my components are about as top of the line as you can get before you get into extreme competition comps.
the woofers give the "360 degree" sound and subwoofers are always from a single, usu. behind, direction. i have never seen a subwoofer setup for stereo because the frequencies are going to fill the car anyways. almost always the subs are run mono or on a bridged amp because you dont have the applicable effect of "moving" bass. in a concert there will be multiple guitars from different parts of the stage, so we invented stereo sound to give us a more concert like feel. the bass only comes from one guitar. in one place. it does not move so there is no need for movement of sound between speakers. same with a kick drum. its coming from one location, so it needs only one channel because there no necessary "movement" between speakers.
