help with 8 inch rockfords
Old Apr 1, 2008 | 09:08 PM
sbird58's Avatar
sbird58
Default help with 8 inch rockfords
i have 4 8 inch rockfords with 2 sets of wires coming out. so 2 subs on each line. any idea how i should wire them up and what size and kind of amp to use?
thanks
shane
Old Apr 1, 2008 | 10:36 PM
ttocs's Avatar
ttocs
Default RE: help with 8 inch rockfords
This is the first time I have heard of somebody else doing 4 8's, thought I was the only one.......
We will need to know more about the speakers to recommend an amp or how to wire them. We will need the model number to know the impedence/voice coil config to give recommendations.
Old Apr 2, 2008 | 05:38 PM
sbird58's Avatar
sbird58
ok the subs are 4 ohms with 2 inch voice coil 400 watts max power
rfp3408
they are forckford punch HE
the two outside ones are wired to the 2 inside ones.
any recomendations will help i am just wondering what size amp or amps to get and the best way to wire it.
Old Apr 2, 2008 | 05:59 PM
sbird58's Avatar
sbird58
if i have to i can re wire it whats the best way
Old Apr 2, 2008 | 06:15 PM
sbird58's Avatar
sbird58
sorry for posting so much i was also wondering whats needed to connect to stock head unit.
Old Apr 2, 2008 | 06:30 PM
blue stang's Avatar
blue stang
Those subs have a DVC with RMS power range of 50-200 watts each. are the voice coils wired in series or parallel?
Old Apr 2, 2008 | 06:56 PM
07lane40's Avatar
07lane40
wire them in a series/parallel combo to get them at 2 ohms. and get an 800 watt (rms) mono amp to match at 2 ohms.
check this out for the wiring for the subs. dont do .5 ohms (nothings stable there)and 8 ohms is alot an you wont see as much power as 2 ohms.
http://www.the12volt.com/caraudio/wo...p?Q=4&I=42
Old Apr 2, 2008 | 07:04 PM
blue stang's Avatar
blue stang
I think he wants a stereo setup instead of a mono so he can have a left and right chanel.
Old Apr 2, 2008 | 09:17 PM
sbird58's Avatar
sbird58
wire them like this
Option 2 (parallel/series) = 4 ohm load
Voice coils wired in parallel, speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Old Apr 2, 2008 | 10:31 PM
blue stang's Avatar
blue stang
If your going to go mono run the subs parallel and do this:
Option 2 (series/parallel) = 2 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
after that get a 200 to800 watt RMS at 2 ohmsmono(1 channel) amp.
