help plzzzz
Old Apr 2, 2008 | 06:41 PM
aj552's Avatar
aj552
Default help plzzzz
please tell me what kind of sub would work with this amp
http://www.kenwoodusa.com/Car_Entert...fiers/KAC-7204
i just want ONE 10" , because i blew my 10 right now because it was a 4 coil.
i had no idea of how to tell which on worked with it and which ones dont.
Old Apr 2, 2008 | 06:51 PM
07lane40's Avatar
07lane40
Default RE: help plzzzz
dual 2 ohm if you bridge the amp and run it at 4, (or 4 ohm svc)
or a dual 4 ohm if you want to run it at 2. (or 2 ohm svc) off of one channel. dont get a dual 4 or single 2 ohm vc if youre going to bridge it. it doesnt look to be compatible with bridging down to 2 ohms...
now just pick the brand you want with those configurations...
Old Apr 2, 2008 | 06:53 PM
blue stang's Avatar
blue stang
you will want a sub that has an RMS of 500 watts at 4ohms or 250 watts at 8 ohms. the brand is up to you because people will argue all day about them. post some links to subs you like and think might work and we will tell you if it is a good match.
Old Apr 2, 2008 | 06:58 PM
blue stang's Avatar
blue stang
^^^^yes. If it were up to me I would get a 500 watt8ohm duel voice coil. run the coils parallel so its at 4ohms total.
Old Apr 3, 2008 | 12:02 AM
aj552's Avatar
aj552
ok ok
but can i get suggestions of what kind of subs plz?
im looking for a clean sound such as alpine
but i still dont get which one of these would work
#1 http://www.alpine-usa.com/US-en/prod...odel=SWR-1042D
or
#2 http://www.alpine-usa.com/US-en/prod...odel=SWR-1022D
Old Apr 3, 2008 | 12:14 AM
ttocs's Avatar
ttocs
ORIGINAL: blue stang
Yup, these are the important numbers, and should be taken as the gospel to anyone shopping at BBY/CC/or walmart. This will be my favorite stupid post until I start to rate a few more... Don't worry, I am sure you will score more then a few, it is still early in the contest.
Old Apr 3, 2008 | 12:19 AM
aj552's Avatar
aj552
thanks for the compliment lol?
just a question.....
Old Apr 3, 2008 | 12:23 AM
ahittz24's Avatar
ahittz24
Get a different amp. start over. FAIL
Old Apr 3, 2008 | 01:22 AM
ttocs's Avatar
ttocs
SPOF #5.
Old Apr 3, 2008 | 08:41 AM
07lane40's Avatar
07lane40
your subs dont care as to the wattage coming to them in the ohm load they only care how much power and how clean the signal is. 500 watts is 500 watts whether its wired at 16 ohms or 1 ohm as long as the amp can produce the 500 watts at the impedance that your subs are wired to.
meaning that a 4 ohm DVC thats rated at 600 watts RMS can handle 600 watts at 2 ohms or at 8 ohms. you just need a pretty powerful amp to get 600 watts at 8 ohms.
