shaker 500, in line converter help
Old Apr 3, 2008 | 12:55 AM
crashed1st2's Avatar
crashed1st2
Default shaker 500, in line converter help
want to add power acoustic lt980-2 amp with 2 12" kenwood subs to 07 gt with shaker 500.
i purchased a scosche in line converter and want to tap into rear speakers in trunk. i have no money for new head unit and already had amp and subs in last mustang with a alpine hu. has anyone used this scosche fai-3a converter and spliced into the rear speakers with good results? if so can you help me with some directions/tips.
this stang wants some more bass!!!
Old May 21, 2008 | 02:03 PM
lharville1's Avatar
lharville1
Default RE: shaker 500, in line converter help
You can do that but it will change the impedance. It will be 4 ohms if you tap because you would have a parellel set up. I have done it several times and it should sound fine. Won't hit as hard as 2 ohm though. you only need to tap 1 channell though because you want to run mono to the 2 subs.
GPR
Dec 16, 2015 12:21 PM
Oct 7, 2015 07:02 PM
LivingInThePast
Sep 16, 2015 12:20 PM
rksnow1
Sep 14, 2015 08:46 PM
Mikett
Sep 12, 2015 10:52 PM
