Room for ?? in 93 notch
Old Apr 14, 2008 | 06:42 AM
seight311's Avatar
seight311
Default RE: Room for ?? in 93 notch
Okay, so i should disconnect the dash speakers, run two decent door speakers off a 2 channel amp, leave alone or disconnect the rear speakers? and then run two sq10's in the trunk.
Shopping list:
2 x 5.25's ------Nope 6.5"
1 x 2 Channel Amp (any recomendations?)-------What does your budget allow?
2 x SQ10's (the 2 or the 4 voice coil? whats the difference) -----You really want SQ10's? Are you trying to save space or...?
1 x nine.2 --------------------This depends if you really want the SQ10's
Wiring kit --------------------Anywhere, 4 ga would work fine. You can get one from eD if you like, or from pretty much any online store, knu conceptz has tons that are very easy on the wallet.
Box making materials, etc
------------ Any hardware store that sells lumber, a sheet of 3/4" MDF should be more than enough to build a box for your rig. Some wood glue, screws (coarse, 1 1/2-1 5/8 is plenty), some silicon based sealant, carpet if you want to make it look pretty.
Old Apr 14, 2008 | 08:41 PM
mattlowe01's Avatar
mattlowe01
Will 6x5's fit in the door?
The 2 channel amp will be in the future, so probably 150-200$
The sq10's, i have almost no trunk space in the notch. I would like to leave as much as possible. Do you have any other nice 10's you would recommend?
Old Apr 15, 2008 | 04:48 PM
seight311's Avatar
seight311
ORIGINAL: mattlowe01
Not 6x5's. 6.5's. 6 1/2's if you will.
NINe.2 if you like the eD products
Unless you have a depth restriction, why not go with a pair of 11Kv2's or 11ov2's... They're not really that much deeper, just makes a difference if your trying to put them in a regular cab truck.
SteelerNation82
Mar 9, 2025 11:40 AM
2007CalSpec
Dec 13, 2020 11:42 AM
baddog671
Jul 26, 2016 01:20 PM
ohfarrell
Oct 18, 2015 11:27 PM
teeeeg67
Sep 1, 2015 11:53 PM
