Please help with AVIC nightmare !!!!!!
Old Apr 23, 2008 | 06:33 PM
Bullitt#3949's Avatar
Bullitt#3949
Default Please help with AVIC nightmare !!!!!!
Hello all. my first post i wish it was with better circumstances. I just got a new bullitt.
I had an avic d3 installed in what was suppose to be one of the best shops in my area. I ran into a few problem i need to sort out before i go back there for them to fix my problem. First it sounds really bad....there is hardly any bass not that the shaker 1000 was the best ever but it had some bass. no matter what adjustments I make in the settings i can get rid of the tinny sound from the system now? could it be hooked up wrong? What settings are you guys using? also the head unit is in crocked with gaps. Did yours fit flush? Also does he illumination dim when you turn your head lights on because mine doesn't. After the installation my ambient lighting switch does not work...no power...anyone else have this problem? What satellite tuner did you use with the D3 for Sirius? And were you able to reuse your factory antenna because they told me it wasn't possible, but I've read on forums that you can...what are you guys doing to reuse your factory Sirius antenna? On a side note they scratched my shift ball and parking brake handle which they said they would fix....please help me with this nightmare.
Thanks Guys
Scott
Old Apr 25, 2008 | 04:03 PM
seight311's Avatar
seight311
Default RE: Please help with AVIC nightmare !!!!!!
Get your scratched parts fixed, get all your money back and go elsewhere.
DO NOT under any circumstances allow them to do anything else for you. If something like that ever rolled out of the shop I worked at and no one said anything about half of the features not working and the SQ being so terrible. I would have been fired.
Unless they offer to fix everything to your satisfaction and do it all free of charge and give you the unit free, go somewhere else.
Old Apr 25, 2008 | 08:48 PM
ttocs's Avatar
ttocs
eh, I am torn there. It sounds like there are a couple of little things they are missing and it may still be fixable but as he said it never would have rolled outta my shop soundin bad. You paid for the install so they should do it and do it right, give then the chance to fix it.
No bass, are the subs on at all? Does it make a popping noise when you turn it on?
What shop?
Old Apr 26, 2008 | 03:58 PM
Bullitt#3949
i will be taking it back on monday morning to get it fixed. This will be at there other store. I spoke to the owner today he said he will make everything right. This will be there one and only chance at fixing this. I have detailed pics of the damage and the bad install. I will let you guys know hiw this turned out and what shop it was on Monday.
Stay tuned
Old Apr 26, 2008 | 05:01 PM
seight311's Avatar
seight311
Good move.
Let us know man, what shop is this by the way?
Old Apr 26, 2008 | 08:44 PM
lundis's Avatar
lundis
1) they need to hook up the shakers, they are prob disconnected.
2) they need to replace your shifter.
3) they need to straighten the radio.
4) they need to use your stock antenna...altough i myself, im not sure if this is possible, i would imagine so.
5)reconnect your ambient switches, they have to be disconnected to get the radio out, the dip**** didnt re-conect them.
6) FIRE THAT INSTALLER!!!
trashxtrash
Sep 20, 2015 10:49 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
blind1595
Jul 18, 2006 10:07 PM
Outatime
Mar 31, 2006 09:56 PM
