subs not working
Old Apr 24, 2008 | 09:37 AM
stangman2354's Avatar
stangman2354
Default subs not working
For some reason they aren't working. they sat for about 2 months, but I wouldn't think that would do anything? My amp turns on. Does the remote wire help turn on the amp or will the amp turn on if the remote wire isn't attached?
Old Apr 24, 2008 | 10:49 AM
joeybutts's Avatar
joeybutts
Default RE: subs not working
remote wire must be connected.
Old Apr 24, 2008 | 12:04 PM
stangman2354
yea im pretty sure its connected because the amp turns on my friend just told me that it needs to be on for the amp to turn on and the amp turns on so it is connected, but what else could make my subs not be working?
Old Apr 24, 2008 | 12:16 PM
TI302's Avatar
TI302
do you have RCAs ran into the amp?
Old Apr 24, 2008 | 03:26 PM
ttocs's Avatar
ttocs
blown fuse on the power wire. Go look up by the battery.
Old Apr 24, 2008 | 08:39 PM
boss_5pt0's Avatar
boss_5pt0
Amp won't turn on with blown fuse. Check your RCAs in the back of the head unit and to the amp.
Old Apr 26, 2008 | 02:03 AM
stangman2354
ORIGINAL: boss_5pt0
yea they're plugged in. I just really hope my subs aren't blown, so besides that what else could it be?
Old Apr 26, 2008 | 10:08 AM
ttocs's Avatar
ttocs
it could be a million things from a bad ground to a disconnected speaker. I would start at the speaker and work my way back.
Old Apr 28, 2008 | 01:49 PM
ssv6ponypower's Avatar
ssv6ponypower
check to see that the wires inside of the box are connected and also the rca's are a big thing as well you could also cut into a little more of the wire to get fresh wire to make sure there is a good connection
Pyrate Dave
Sep 10, 2015 07:30 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
