custom speaker mounts need help
Old Apr 28, 2008 | 12:46 PM
richmustang1880's Avatar
richmustang1880
Default custom speaker mounts need help
So i already have 6.5 focal comps fited in my door and stock mid/tweeter positions.(hadthe mach 460) My birthday is coming up next month and im getting cdt upstage tweeters(http://www.woofersetc.com/index.cfm?...roduct_ID=3087).I am going to mount the focal tweeter where it should be next to the mid woofer and mount the new tweeter in the a-pillar. The problem is i want to take out the factory grill and make custom mounts where the orignal gril was. So i can angle them properly and it willlookbetter.i dont know how i would mount the speaker mounts. should i mount them to the door panel or to the sheet metal and if i mount them to the sheet metal how would i get the door panel back in because they have to be pushed down to lock in.???
Old Apr 28, 2008 | 05:50 PM
richmustang1880
Default RE: custom speaker mounts need help
...bump
Old Apr 28, 2008 | 09:18 PM
ttocs's Avatar
ttocs
I don't really understand what your asking. You want to put it in your a-pillar which I understand but what do you want to do with the factory grill? factory ford or CDT?
It takes a bit of practice to get it molded smoothly into the pilar.
Old Apr 28, 2008 | 09:52 PM
PReal's Avatar
PReal
Don't do it!!!!
The upstage kit is a bandaid for a poorly laid out front stage. (This coming from mister CDT)
If you are going through the trouble of makeing some tweets fit in the sail panels, put a set of tweets in there and ditch the CDT idea.
Also, What amp are you using on those comps. If you dont have one yet, your money will be much better spend on an amp then the upstage kit.
Old Apr 29, 2008 | 09:57 AM
richmustang1880
no i have an amp. so preal your saying i should basically leave it the way it is with my tweeters mounted in the factory mach460 locations? and ttocs i ment reomoving the factory grill and custom building mounts for the speaker that would replace themso basicaly the speakers would be flush with the door panel so the sound waves would not be obstructed, at least by the door panel.
i understand all of the sound waves (physics major) but i dont have the money for three ways and i would have to custom mold them to get them to sound right also. trying to make what i have work to the best of its potential. dont know if you need to know but i have a Orion Cobalt Series CS500.5 5 Channel Amplifier, focal access 165 a1(woofer in stock location tweeter in mach460 mid/ tweet location),mach 460 stock speakers in the back just for fill lp 250, a 10" kicker cvr in a sealed box. and about a hundred dollars to work with.
Old Apr 30, 2008 | 12:08 AM
ttocs's Avatar
ttocs
what more are you wanting from the system? What is it lacking that you want to fix?
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
jrrhd73must
Oct 2, 2015 09:17 PM
mdg
Oct 1, 2015 07:04 AM
Sixer4Life
Sep 29, 2015 07:03 PM
