My Car pc! 56k Warning!
Old May 25, 2008 | 09:05 PM
SVTBill's Avatar
SVTBill
Default RE: My Car pc! 56k Warning!
maybe you can get a program that logs what happens to the car. that way you can set it up before you take it in for service and see if the techs are beating the crap out of your car. if they are you have proof of it all!
nice buy - how much did it run you?
Old May 25, 2008 | 10:26 PM
ttocs's Avatar
ttocs
shouldn't be too hard to set up a camera to record to the hard drive.......
Old May 26, 2008 | 01:48 AM
Xargon321's Avatar
Xargon321
I cant take the face off this its a Computer built into the dash thats a 7" touch screen its custom built except the metra kit i used to make it look like it belonged there. it probably has cost me about 2k in parts after its all said and done. that thing next to the switches is a 4 port usb hub i know it looks unfinished but im going to built a power circut for it and when i take it out to do that ill epoxy it in place and put some body filler around it and paint so it looks like it was always there
Old May 26, 2008 | 07:33 PM
ttocs's Avatar
ttocs
I hope you don't think that I don't like it, that is not the case. The time and effort you put into it came across with its clean stock looking appearance, you did a very good job to say the least.... I have seen others try and not get such a nice package out of it. I understand the face is not removable, I was just saying what I do to fix it. IF you wanted to get a little more creative I hade considered using a relay and an unused output on my alarm to make a valet-safe mode that would look completly normal to any person but would completely render the system unusable.
I commented on the usb port looking unfinished as nothing more then a bit of constructive critisism since that is the only point that I could see anything wrong with. I made a usb port for another member here to fit into his coin holder. It is on page 11 of my cardomain page, came out perty nice... Let me know if you want something similar and I can mold it into the dash and make it look like it belongs there for ya.
in general though thanks for sharing with us.
Old May 26, 2008 | 09:27 PM
Xargon321's Avatar
Xargon321
sorry, i wasnet trying to come acrossed like that, i thought by one of your posts that it was a standard head unit with a removable face, im happy with the valet switch as it is. its inside the center console and not readily visable unless you looke in there, i figure that most shop people wont go looking for the switch. i put the switches and the usbhub together in a hour or two just to get it that part going as i had it freeze one time and didnt have a way to restart it as the power supply was on a 2 hour hard off timer. i have changed the power setting on the power supply so it cuts power off much sooner but still wanted to have a switch so i didnt have to pull over and shut the car off to get it to restart. i also left the stock harness intacted as well i used a metra wiring kit to power the psu off the radio circut as it supplys more then enought current to power it all except for the speakers amp of course.
as to the usb hub im going to try and make it sit flush and use some body putty so smooth out the lines so all you will see is the usb ports im also going to use a relayed circut to power the usb hub i have a 5v 3a vreg that i will tap into the power port in the center console to use so when i tuen on the car itll will power the usb hub and not drain my battery when the car is not on. thanks for the offer tho.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
