Replacing Mach 460 Amp
Old May 2, 2008 | 02:37 PM
5.0LitreSN95's Avatar
5.0LitreSN95
Default Replacing Mach 460 Amp
So, I recently got a new deck installed. They wired it wrong and blew my sub amp, and are refusing to fix it because "We just wired it the same way the last deck was." They re-wired it the correct way (thanks ttocs) and suggested I get a stock replacement amp. I couldn't find a stock replacement locally.I figure I'll haveto replace it with an aftermarket amp. My question is: are there any special things I need to know about putting in an aftermarket amp?
Old May 2, 2008 | 09:09 PM
Sxynerd's Avatar
Sxynerd
Default RE: Replacing Mach 460 Amp
Use a quality amp wire kit. I'd go with either a rockford or the new Alpine 4 channel.
Old May 3, 2008 | 03:12 PM
ttocs's Avatar
ttocs
if you add an aftermarket amp to stock woofers you wil not be happy. The stock 8 ohm woofers will draw very little power from the aftermarket amps, this with the small size is a formula for bad sound. Have you stared simple and checked all the fuses to see if any are blown, turning the amp off? Under the hood? What do you have playing now(equipment wise)?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Art161
Sep 9, 2015 10:33 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
