AVIC-D3, 2007 Pony and subs
Old May 7, 2008 | 06:55 AM
luvrbcs's Avatar
luvrbcs
Default RE: AVIC-D3, 2007 Pony and subs
ORIGINAL: Xargon321
Also the subs are mono and both are wired together before the amps so to get the best signal you will have to mix the left and right channels before going into the fatory harness
How do I do that?
Old May 7, 2008 | 10:03 AM
ttocs's Avatar
ttocs
I have no idea what he is talkin about. Check to see if you have voltage on the blue/white wire. Do you have and know how to use a voltmeter/testlight?
Old May 7, 2008 | 10:33 AM
disturbed471985's Avatar
disturbed471985
woo argon must have pulled that out ur a**.
Old May 7, 2008 | 11:04 AM
luvrbcs's Avatar
luvrbcs
ORIGINAL: ttocs
I will be checking that over the weekend.
Yes, I can use a voltmeter.
I think I may have reversed the wires going to the voltage regulator. I will know for sure when I test it.
That is the only thing I can think is wrong.
Woohoo, 200 posts!!!
CS2007
Jun 25, 2019 09:45 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sixer4Life
Sep 29, 2015 07:03 PM
