remote wire
Old May 13, 2008 | 10:19 PM
ExtrmZ's Avatar
ExtrmZ
Default remote wire
what are some things that i can splice into to get the power to the amp? my deck doesn't put out enough
Old May 13, 2008 | 11:34 PM
Cooter's Avatar
Cooter
Default RE: remote wire
Are you talking about the remote wire off theback of your radio?? Is it a factory deck or aftermarket??
I'm really not sure what you mean by your deck doesnt put out enough.
Old May 14, 2008 | 10:56 AM
mrdeep2001's Avatar
mrdeep2001
I'm assuming he has an aftermarket radio. Think he means the remote wire that goes from the radio to the amp is not getting enough power to turn the amp on.
How did you go about testing this?
Old May 14, 2008 | 06:04 PM
ExtrmZ's Avatar
ExtrmZ
what can i hook it into? that will put out 12 volts
Old May 16, 2008 | 05:09 PM
seight311's Avatar
seight311
Your deck should "put out" plenty.
It only takes a couple volts toswitch on an amp, if this seems like an issue I would look into some other things cause the deck not putting out enough power to turn on your amp is not the case.
Old May 16, 2008 | 09:57 PM
ttocs's Avatar
ttocs
we need more info, what equipment do you have? The stock stereo uses a 6v turn on rather then a 12v so that is the only thing I can think of. The remote turn on is just a 12v, low current signal that does nothing more then turn on a relay to allow the amps to draw power from the main power wire.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
cbird1177711
Sep 3, 2015 08:43 PM
