sub wont go on
Old Jun 13, 2008 | 12:45 PM
bluestang23's Avatar
bluestang23
Default RE: sub wont go on
ORIGINAL: ttocs
ORIGINAL: The Noland
i know this may not be the problem
but,
my friend had a problem with is subs the other day
he even went so far as taking it to besy buy and they couldn't find it
while we were there, we looked at the amp, and it turned out, the eq thing was sent to flat
he flipped it back to the other side and it turned right on
just an idea
haaaaaaaaahahahahahahahahahahahahaaaaaaaaaaaahahah ahahaha lol.
You took it to worst lie to fix it? man that is desperate and you are just setting yourself up for failure there. They couldn't finger it out? REEEEaly???
Again I would get that cable and do my test real quick. It should not cost more then $10 and will tell you immediatly if the problem is the deck/rca's or if it is the amp.
It is possible to turn off the sub output on some decks, I am not familiar with yours. Have you checked to see if the rcas are still plugged into the deck?
i checked all the RCA cables and took the deck out again. it all looked good. umm ill try to get one of those cables later today to test it with my Ipod. i think im also gunna take the sub out and hook it up to my home theater system to make sure it works.
thanks for all the help guys. i just hope i get it working again even if i have to throw some more money at it.
Old Jun 13, 2008 | 01:29 PM
PReal's Avatar
PReal
If you have some speaker wire, to make sure your subs work in the box just use a small household batter on the positive and negative wiring and see if the cone moves. Way easier then hooking up to HT.
Do you have a voltmeter. That would also be a great tool to diagnosing your issue and you can buy one for less then $15 many places.
Old Jun 13, 2008 | 01:35 PM
bluestang23
ORIGINAL: PReal
a batter?
Old Jun 13, 2008 | 02:35 PM
PReal's Avatar
PReal
Sorry...
Battery.
Old Jun 13, 2008 | 03:31 PM
bluestang23
oh. like a 9v
Old Jun 13, 2008 | 04:46 PM
bluestang23
i hooked some RCA cables to my Ipod. it didn't work.
Old Jun 13, 2008 | 05:10 PM
ttocs's Avatar
ttocs
ok, you had the deck in the car on, the volume on the ipod up, and connected the rca's to the input on the amp right? Test the sub with a battery or an ohm meter and tell us what you have.
Old Jun 13, 2008 | 06:02 PM
bluestang23
ORIGINAL: ttocs
yes. the deck was on and i turned it on high. (the amp light wentgreen also)i also turned the ipod on all the way up and hooked it to the amp input. i tried the sub with a D battery... its all i had. but im going to bring it in and hook it to my stero because it didn't work.
Old Jun 13, 2008 | 06:29 PM
bluestang23
well i hooked it up to my HT system and it was a no go. i guess that means its dead? the sub was kind of old. it was a single 12in kicker compvr. but it was an older one.
Old Jun 13, 2008 | 07:24 PM
PReal's Avatar
PReal
Take the woofer out of the box.
Get yourD battery.
Connect some wires to the terminal on the sub.
Touch the wires to the ends of the battery.
If the cone does not move, you need a new sub.
