amplifier placement
Old May 1, 2005 | 05:00 PM
mk49's Avatar
mk49
Default amplifier placement
I was wondering what options I have for placing amplifiers in an 05 Mustang. I'd like to avoid putting them in the trunk. Is there any room under the rear seats? I want to put JL Audio 300/4 and 500/1. In my 01, I screwed them to seatbacks, but I think that is tacky. Any advice??
BTW.. my Mustang is on order. If I had it, I would disassemble the rear seats to see myself but I figured somebody out there has already done this...
Old May 3, 2005 | 09:02 PM
fastmustangs1's Avatar
fastmustangs1
Default RE: amplifier placement
In back of seat. That is were mine is.
Matt
Old May 3, 2005 | 10:29 PM
mk49's Avatar
mk49
I am thinking that is my only choice. Not a bad choice, but I was trying to maintain some trunk space. Placing the amps on the seatbacks will push the sub box about 4 inches to the back. I was hoping there is a magic spot....
Old May 11, 2005 | 08:10 PM
01roushnj's Avatar
01roushnj
my tuner for my touch screen was quite large so i took the passanger seat out and mounted it under there, its very stealthy....but the amp might be alittle too big but try it anyway.
Old May 11, 2005 | 09:14 PM
Jimmz's Avatar
Jimmz
It depends on how big the amp is. If its small enough then mount it under the passenger seat. If not then you can always mount it on the box (side,back,top) etc. I have mine in a custom box I made on the side, kinda where the fenderwell is, so that its flush and it saved a lot of room. Ill take some pics of it tonite so you can see what im talkin about...
Old May 11, 2005 | 09:42 PM
mk49's Avatar
mk49
I would like to see how you did that (custom box in fenderwell). I am thinking about a combination of 2 reply's in this post. I can possibly put the smaller amp under passenger seat and the larger one in a custom mount in the trunk. Thanks!!
Old May 11, 2005 | 10:29 PM
GreyStang's Avatar
GreyStang
I'd think an amp stuck under a rear seat would start overheating pretty quickly...
Old May 12, 2005 | 01:49 AM
tcuallstar's Avatar
tcuallstar
how big is the sub box? just tack it on the back of there. then that way when you need room for travel it all comes out as one unit.
Old May 12, 2005 | 10:47 PM
mk49's Avatar
mk49
yea, the rear seat idea is probably out...
as for the sub enclosure, it's a good idea, but disconnecting the amps to get the subs out would be a big deal. I don't think I want to be doing that. On the other hand, I am trying to come up with a config that keeps me from needing to pull the sub box out, so I'll see how much clearance there is around the outside of the enclosure.
Old May 13, 2005 | 12:53 AM
dc_mann8's Avatar
dc_mann8
make sure u have a lot of air getting to it, dont need it getting hot and blowing.
69FB
Aug 18, 2015 08:50 PM
babyvamp101
Nov 3, 2005 10:24 AM
Epd711
Mar 10, 2005 02:03 PM
narc29
Dec 15, 2004 03:41 AM
