panel problem
Old Jun 29, 2008 | 10:03 AM
hockeynick's Avatar
hockeynick
Default panel problem
I have a 2000 mustang. I am installing new rear speakers. I have gotten the panel directly behind the rear seats off. My problem is coming from the carpeted panel directly above the rear seats. I popped the 2 front push pins out but I cannot figure out what else is holding it on. I do not want to force it off and risk breaking it. Is there an easier way?
Old Jun 29, 2008 | 12:36 PM
hockeynick's Avatar
hockeynick
Default RE: panel problem
Nevermind I figured it out. I has to take the upper left panel off including the clothes hanger and seatbelt.
From another thread.[align=left]REAR DECK SPEAKER INSTALLATION:[/align][align=left]NOTE: THE FACTORY SPEAKER PROVISION IS FOR A 6 X 8" FORD STYLE[/align][align=left]SPEAKER[/align][align=left]1. FOLD DOWN REAR SEAT BACKS.[/align][align=left]2. REMOVE (3) 10 MM BOLTS ACROSS FRONT OF REAR SEAT UPPER PAD.[/align][align=left]3. REMOVE (1) PHILLIPS HEAD SCREW TO REMOVE CLOTHES HOOK.[/align][align=left]4. REMOVE SEAT BELT SWIVEL USING A T-50 TORX BIT.[/align][align=left]5. REMOVE (1) PUSH-PIN STYLE PANEL FASTENER JUST BELOW SEAT BELT[/align][align=left]SWIVEL.[/align][align=left]6. USING A PANEL REMOVAL TOOL, GENTLY PRY OUTWARD STARTING AT[/align][align=left]FRONT WORKING TOWARD REAR ON THE REAR PASSENGER WINDOW[/align][align=left]PANEL., THEN REMOVE.[/align][align=left]7. USING PANEL REMOVAL TOOL GENTLY POP OUT (2) PANEL FASTENERS[/align][align=left]AT THE FRONT OF THE REAR DECK.[/align][align=left]8. SLIDE REAR DECK COVER FORWARD TO REMOVE.[/align][align=left]NOTE: MACH-460 SYSTEM HAS A SPEAKER ENCLOSURE WITH A 6 X 8"[/align][align=left]SPEAKER AND A 2 1/2 TWEETER. ONE RIGHT AND ONE LEFT ENCLOSURE.[/align][align=left]NOTE: MACH 460-SYSTEM HAS AN AMP RACK UNDER THE REAR DECK[/align][align=left]WHICH HOLDS 2 FACTORY AMPS; ONE FOR EACH PAIR OF 6 X 8"S IN[/align]MONO, WHICH ARE MID-BASS SPEAKERS
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
Gkid182
Sep 22, 2015 08:17 AM
Shawmp
Sep 18, 2015 07:52 AM
2k232
Sep 16, 2015 10:28 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
