Do you think this will work??
Old Jul 9, 2008 | 01:06 PM
Lando7886's Avatar
Lando7886
Default Do you think this will work??
i have a 2001 black v6 and i ordered two 12" alpine type r subs and plan on putting them in the trunk with this box
http://www.sonicelectronix.com/item_...Enclosure.html
do you think ill be able to fit it into the opening?
Thanks for the help
Old Jul 9, 2008 | 08:27 PM
GTRedfire03's Avatar
GTRedfire03
Default RE: Do you think this will work??
NO it will not fit going throught the trunk lid opening, well i take that back yes but you have to pull the spare tire out then try to fit it in there plus they get the carpet and the spare tire back in. Have fun with that.
Do you have the mach 460?
Well what you can do is pull the bottom of the back seat out, they unbolt the back of the back seats. That should let you slide the box in throught the back seat opening in side the car.
Old Jul 9, 2008 | 08:56 PM
Lando7886's Avatar
Lando7886
no i dont have the mach 460 i bought some dynamat extreme too so im gunna be takin my trunk apart as it is... but how hard is it to take out the back seats?
Old Jul 9, 2008 | 09:08 PM
GTRedfire03
Not too bad if you reach your hand under the bottom of the back seat there will be a white(clear) botton that you push to release the bottom of the seat. Then if you have it unbolt the headrest part on the back seat, fold the back seat down, andthere are 3 5/16 bolts there if you have the head rest part.
I for get the size and how many but there should be a couple big bolts that hold the back seat part on and after you pull that out it will open and you should be able to slide that box right in.
Dynamat First before you put the subs in. It is alot easlier to dynamatwithout alot crap in your way back there.
Old Jul 9, 2008 | 10:13 PM
Lando7886's Avatar
Lando7886
ok thanks for the help.. i have one more question im not sure if this is a stupid question but where exaztly am i supposed to dynamat i know the trunk lid and below the spare but im not sure what else thanks
Old Jul 10, 2008 | 01:58 AM
ttocs's Avatar
ttocs
you will save yourself alot of trouble if you get two, single 12" boxes. You can load them from teh back one at a time, then screw them together to make one box and then mount your subs in them.
Old Jul 12, 2008 | 10:38 PM
Audiofreak19's Avatar
Audiofreak19
honestly your just wasting your time with that i would have just gotten 10 inch type r's cause there not gonna sound any different and they will look better in that trunk cause if you get those 12 inch ones in its gonna look like a fat guy in a little coat.
Old Jul 17, 2008 | 10:40 AM
GTRedfire03
ORIGINAL: Audiofreak19
Honestly 2 12s will hit alot louderthen 2 10s. 12s will hit those lower freq. alot better then 10s will. I have 10s bc i listen to all types of music. If you listen to alot of rap and want to be heardthen 12s will let you be heard 3 miles down the road. Yes 12s will like huge in the back of a mustang bc how big the trunk is but i have done 2 15s in a mustang before if you want to talk about a "fat guy in a little coat".
Back to the question at hand. I would atleast dynmat the trunk lid, the rear deck where the rear speakers are mounted, the floor, well hell do the sides too, so i guess the whole trunk. It isbetter if you do it the the first time instead of having to pull everything back out and dynmatting more.
Bc im sure that box wasnt fun to get in. Did you get the box in?
Old Jul 25, 2008 | 10:03 PM
Lando7886's Avatar
Lando7886
suprisingly the box was easy as hell to put in i had to take out the carpeting and spare and angeled it in then i had to slide the carpeting underneath it and was able to squeeze the spare back in.. the only promble is that the jack that goes with the spare didnt fit but overall it was a success.
i dynamatted the entire trunk lid which made it sound a thousand times better and doesnt even look that bad and dynamatted under the spare and inside of the trunk opposit the license plate. i could post pics if u want i think it turned out nice
Old Jul 25, 2008 | 10:08 PM
bumpinvert's Avatar
bumpinvert
Ya post some pics if you can. For future reference pics are always welcome.
