No sound with stereo install
Old Jul 12, 2008 | 02:17 PM
yeshmiester's Avatar
yeshmiester
Default No sound with stereo install
I'm installing a pioneer stereo into my 2000 v6 with premium sound following the directions on Install Doctor. I bought a wiring harness from metra (the 80-5511) and am using the factory amplifier integration method. I just finished splicing and attaching all the wires and put everything into the car... but I'm getting no sound. The unit powers up and I am able to detect radio stations but again no sound.
Wires from the metra harness that are not connected: Amp turn on, Dimmer, Power Antenna
Wires from the pioneer's harness that are not connected: Mute, System control
Stereo's ground is attached to the large black ground wire that was attached to the factory stereo.
Any ideas of what I am doing wrong?
Old Jul 12, 2008 | 02:26 PM
yeshmiester
Default RE: No sound with stereo install
For the system control wire in the pioneer harness install directions says: "connect to system control terminal of the power amp or the auto antenna relay control terminal"
Should I connect this wire to the metra harness' wire for amp on?
Old Jul 13, 2008 | 12:52 AM
ttocs's Avatar
ttocs
the install dr should tell you to connect the remote turn on from the deck to the amp turn on in the hrns.(blue/white to blue)
your amps will probably turn on with a loud thump. The sticky on the top of the audio forum tells how to fix this.
Granatelli Sales
Jan 20, 2020 12:34 AM
drfister
May 3, 2018 10:38 PM
cbird1177711
Sep 2, 2015 04:12 PM
SYNY5TER
Sep 2, 2015 01:35 AM
