Engine "whine" audible through speakers
Old Jul 19, 2008 | 09:36 PM
kingbri1's Avatar
kingbri1
Default Engine "whine" audible through speakers
Just recently I've noticed that I can hear the engine "whine" through the speakers. The pitch gets higher and louder thru the rev range. Anyone know what would cause this and how to fix it?? It's wicked annoying and seems to be getting worse.. thanks
Old Jul 19, 2008 | 11:55 PM
Piraya33's Avatar
Piraya33
Default RE: Engine "whine" audible through speakers
You need a ground loop isolator. They are pretty cheap and Circuit City/Best Buy carry them in their car audio departments. I'm not exactly sure, but I think it is caused by the turning of the flywheel somehow. Someone else correct me if I am wrong though. I had this problem pretty bad on my car. I installed a ground loop isolator and the problem disappeared. Good luck!
Old Jul 20, 2008 | 03:24 PM
AudioNutz's Avatar
AudioNutz
Where is your head unit grounded? If you pull the RCA's out of the amplifier, do you still have noise?
Old Jul 21, 2008 | 01:54 AM
ttocs's Avatar
ttocs
ground loop isolators are a band aid over a wound that will never heal.
Before we could give any help we need to know what is in the car
Old Jul 21, 2008 | 07:12 PM
1HottMach's Avatar
1HottMach
+1
Yeah Dude Ground loop is a last resort... Have you recently done anything to the sound system or add any new Mods or anything? There are a bunch of ways to pick up that noise so you kinda wanna retrace your steps if you added anything recently. If you haven't added anything recently and the noise just came outta the blue then there are different things u want to inspect..
Old Aug 2, 2008 | 12:31 AM
TC3K101's Avatar
TC3K101
if you have a aftermarket cd player u can ground ur rcas, check ur grounds on ur cd player. also is ur cd player a pioneer?
Old Aug 5, 2008 | 11:32 AM
GTRedfire03's Avatar
GTRedfire03
ORIGINAL: kingbri1
Guess you fixed the problem. Seen we are not getting any help with what you have in the car.
Aftermarket or factory?
Old Aug 7, 2008 | 09:14 AM
ttocs's Avatar
ttocs
in the industry we call this an audible tachometer. No reason to ever miss a shift, even if your favorite song is on!
unit91
Sep 15, 2015 09:53 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
