need some help
Old Aug 13, 2008 | 06:52 PM
stangant's Avatar
stangant
Default need some help
i just bought the bezel for the new edge style mustang that is a single radio port. it does not seem to have a lip to install the radio. is there a how to on it cuz i can't seem to find one.
Old Aug 14, 2008 | 06:15 PM
stangant's Avatar
stangant
any1?
Old Aug 15, 2008 | 07:59 AM
GTRedfire03's Avatar
GTRedfire03
What year is the bezal for 99-00 or 01-04? Picture maybe? What year is the car your putting this on?
Old Aug 15, 2008 | 04:52 PM
ttocs's Avatar
ttocs
I am not as familiar with the double din mount but they normally mount differently. Pics would help alot......
Old Aug 15, 2008 | 10:08 PM
stangant's Avatar
stangant
ok will get those up
Old Aug 15, 2008 | 10:22 PM
stangant's Avatar
stangant
its going into a 2000 but from an 01
Old Aug 17, 2008 | 03:38 PM
stangant's Avatar
stangant
and what do u think?
Old Aug 19, 2008 | 10:59 AM
GTRedfire03
Should work but the only thing is how you will mount the deck in there. On your factory dash the radio was held in with the ford clips, well on the 01-04 there is no for ford clips. The radio has a mounting bracket on the bottom of the factory deck that mounts with 2- 9/32(7mm) bolts to the mount behind the dash.
Go to http://metraonline.com/fit.aspx and search for this part number 95-5026 this is the kit you need for a double din. You will see that there are mounts on the bottom for those bolts. You will have to make some sort of mount to get the new radio to work in there. About 4 1/2 years ago my car was broken into and the aftermarket deck was stolen and the factory mounts on the were broken, so I had to make my own mount to get the new radio in there.
Old Aug 19, 2008 | 09:59 PM
stangant's Avatar
stangant
thank you for a good answer
