wtf no more sound
Old Sep 4, 2008 | 04:16 PM
aj552's Avatar
aj552
Default wtf no more sound
ok idk whats going on but there is no more sound, it was working perfectly last night and today nothing, just letting it sit there the sub made a quick sound and that is it.
i have two amps and they were both on and working and the connections where goood.
whats wrong?
thanks
Old Sep 4, 2008 | 09:09 PM
ttocs's Avatar
ttocs
I assume the deck is still on since the amps are both still on. No sound from nothing?
Old Sep 5, 2008 | 01:35 AM
aj552's Avatar
aj552
no there is no sound. it was doing this mildly last week when i would crank it up, but it came back in just a few seconds.
Old Sep 5, 2008 | 09:11 AM
GTRedfire03's Avatar
GTRedfire03
Is it factory mach 460 and factory headunit with an aftermarket amp and subs or is it all aftermarket 2 amps, 1 amp for the subs and 1 amp for the interior speakers and aftermarket headunit? What year is the car?
If aftermarket amps is the are the amps turning on?
Old Sep 5, 2008 | 11:36 AM
aj552's Avatar
aj552
yeah its all aftermarket 2 amps, 1 amp for the subs and 1 amp for the interior speakers and aftermarket headunit. the car year is 2002.
i have no idea why it would do this, everything is on.
Old Sep 5, 2008 | 05:20 PM
bumpinvert's Avatar
bumpinvert
This happened to me once and it ended up being the remote wire (blue one) was grounded and I guess that turns off all amps because I had no sound from anywhere.
Old Sep 5, 2008 | 09:54 PM
ttocs's Avatar
ttocs
The remote wire is where I would tell you to start but he said the amps still have power.
Check the fuses in the amps
Old Sep 6, 2008 | 12:12 AM
HypromanGT's Avatar
HypromanGT
Might also be the RCAs, although....2 sets going bad at the same time? Probably pretty unlikely, unless you've managed to slice through both sets at the same time. In any case, it's probably best to start from the source and systematically work back (pain in the butt since the head unit is probably the hardest thing to get at, I know).
That's very strange...Good luck...
Old Sep 9, 2008 | 08:07 PM
aj552's Avatar
aj552
ok here is the update, it works but if i push the volume of the deck past 35 it cuts out untill i bring it back down then it comes back............so what would cause this?
is the fuse on the back of the deck gone bad?
Old Sep 10, 2008 | 02:19 PM
ttocs's Avatar
ttocs
what are the gains on your amp set at? This is not a fuse.
