Mach 460 speakers
Old Oct 2, 2008 | 12:13 PM
nickel417's Avatar
nickel417
Default Mach 460 speakers
What are some good Mach 460 speaker replacements?
Old Oct 2, 2008 | 02:12 PM
GTRedfire03's Avatar
GTRedfire03
Factory speakers. When you you try to replace the factory mach speakers you get into different ohms on the speakers.(when the rest of the audio system is factory)
Factory speakers are 8 ohms most aftermarket speakers are 4 ohms. You will get more volume for the aftermarket speakers but the stock mach amps will not be able to handle it.
What are you looking for more volume, clearer sound, or more bass?
Old Oct 2, 2008 | 02:23 PM
nickel417's Avatar
nickel417
volume, bass and clearer kind of... anything I can do to keep the factory amps in place?
Old Oct 2, 2008 | 02:34 PM
GTRedfire03
Do a new headunit and get the metra 70-5521 wire harness. This will intergate the factory mach amps give you some more volume, better all round audio control over the system = cleaner sound. If you looking for little or alot of bass add a sub(s) that is the only way to get any decide bass.
Old Oct 2, 2008 | 07:18 PM
ttocs's Avatar
ttocs
like he said start with the head unit and you can tweek the signal a little to make is sound better. The mach amps really only work with the factory speakers and even then not all that well. Once the deck is replaced you can then easily replace the speakers or add stuff.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
