1990 LX Help
Old Oct 13, 2008 | 12:35 PM
zeekstr's Avatar
zeekstr
Default 1990 LX Help
I bought a 90 LX that did not have a radio. The amp is there.
I want to use the amp. Where can I find a wiring harness so that when
I install the radio and speakers, It will work?
Old Oct 13, 2008 | 02:58 PM
ttocs's Avatar
ttocs
Do you mean it has a factory amp? If so I promise that you do not want to use it. They used cheap parts and had them gained up so high that they were just noise makers. I always recommend bypassing them and thankfully it is easy to do. There should be two wire bundles going to the amp. Follow one up and it will go up behind the glove box and have a pair of hrn's that can be disconnected. Disconnect them and pull the male side back up to the radio(There is enough slack) and get a standard for 70-1770 hrns set and use THAT hrns as your speaker hrns, and you have now bypassed the amp. That hrns goes straight to the speakers.
The hrns you are looking for is the exact same one that I point to on page 2 of my cardomian page. It is an 8 pin hrns that looks like the grey 8 pin power hrns that is behind the radio.
14gt_Track
Oct 1, 2015 02:47 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
adamfrosceno
Aug 27, 2015 07:40 AM
