Viper alarm system
Old Nov 11, 2008 | 09:23 PM
06 Gt on 20s's Avatar
06 Gt on 20s
Default Viper alarm system
i just bought a 2006 gt and it has a viper alarm system installed.
Recently the battery wires were disconnected and now the alarm doesnt make the beeping noise when locked or unlocked. Someone said to disconnect the alarm wire from the battery and it will reset, is that true? i was also told that there should be a reset button hidden somewhere, true?
Old Nov 13, 2008 | 10:51 AM
06 Gt on 20s
anyone have a viper alarm system?
Old Nov 13, 2008 | 04:26 PM
ttocs's Avatar
ttocs
do the doors lock/unlock? Is the led on constant rather then flashing?
If so then Your in valet mode.
Old Nov 13, 2008 | 07:35 PM
06 Gt on 20s
Thats how it is. Do you know how to get out of valet mode?
Old Nov 13, 2008 | 08:16 PM
ttocs's Avatar
ttocs
there is normally two ways..
one if you know where the little black momentary push button is, you push it in with the key on and hold it while turning the key off.
The other way is to open the door, push button one(top left for 1 sec), push button 2(top right for one second), and then push button 1 for a second also. The car will lock the doors once and flash the lights on the first push, it will unlock and flash the lights 2 times, and the third push it will lock the doors and then the led will turn off. At that point the alarm will be in its normally function mode.
Old Nov 13, 2008 | 08:20 PM
06 Gt on 20s
Ok Thanks for the help
Old Nov 14, 2008 | 09:01 PM
ttocs's Avatar
ttocs
did it work?
Old Nov 15, 2008 | 04:38 PM
06 Gt on 20s
yea the second way worked. thanks
Old Nov 16, 2008 | 11:13 AM
ttocs's Avatar
ttocs
you need to know where that button is to turn the alarm off if you ever have the remote malfunction. With a combination of the key and that button you can turn it off
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
