help w/ ground wire
Old Dec 14, 2008 | 02:28 PM
sjd3021's Avatar
sjd3021
Default help w/ ground wire
i have a 93 cobra & im replacing the stereo, the install manual said to attach the ground from the stereo to the chassis. can i just connect it to the ground wire coming from the factory harness? thanks
Old Dec 14, 2008 | 03:33 PM
ttocs's Avatar
ttocs
is there an octagonal box with a bunch of holes under the radio(the factory amp)?
IF you are using an aftermarket hrns that is clipping into the factory hrns then first make sure that the ground wire continues from your hrns to the factory hrns. Sometimes they make the hrns for a bunch of models and what is the ground on one may not be the ground on the other. IF the wire continues into the factory hrns then it is fine to use but a clean spot on the chassis is commonly recomended.
Also be carefull if there is a wire that is black with a white stripe. That is the amplifier ground.
Old Dec 14, 2008 | 04:00 PM
sjd3021's Avatar
sjd3021
thanks ttocs, my amp was under the pass. seat, i removed it & now im using the factory harness thats under the dash on the pass side. i seems easier to connect the ground from the stereo to the harness
Old Dec 14, 2008 | 08:23 PM
ttocs's Avatar
ttocs
good man, you found the bypass hrns! You will be fine with the ground on the hrns.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
