Just got my subs in
i did the install my self it was pretty easy took me about 1 hour to get it done. 2 12" MTX 5500 1800w peak 300RMS each using MTX 600xd amp and capacitor.
Video: http://www.youtube.com/watch?v=MQdNSFzZxWU
Pics:
Setup
Install:
i just drilled a whole through the firewall i found it easier.
for the remote i used one of the radio wires under the steering wheel
for the hi-low i used a converter and took it out from my rear speakers
Pics:
Setup
Install:
i got this protecting thing that covers the wire inside the hood and the hole is too tight to let water in. the reason i got tape is because when i had my frist accedint somehow the sub got cracked at that part so i just glued it and my friend put a tape on it but it sounds the same nothing wrong with it
looks decent i would clean up the wires. and seriously get rid of the cap. all it does is add resistance and take away power from your amp.
learn how to do the big 3 and your voltage should be good
you should get those subs in a ported box. output would increase a decent amount.
if you need help designing a box for those let me know. i would be glad to help
Yeah I agree....Here's a car audio saying "Get rid of the cap ASAP"
You my friend definitely don't need one. As TC3 above me pointed out ..do your grounding kit, there is even a nice write up ^^^^ in the sticky section walking you right through the process.
