Need some sub help
Old Feb 8, 2009 | 07:43 PM
ABQstang89's Avatar
ABQstang89
Question Need some sub help
So i have recently purchased two 12 inch Infinity subs. I have been going back and forth between a sealed box or ported box design for them. I am pretty sure i'm going to go with the ported design. I'm planning on getting rid of the spare tire and putting the subs there. So my question is how should i design my box. I'm going to use the recommended volume and port size from Infinity. So does shape matter to much with this? Where should i put the hole for the sub and port? I was thinking of making two seperate chambers for each sub, is that a good idea? Any feed back would be great guys thanks.
Old Feb 8, 2009 | 08:52 PM
ttocs's Avatar
ttocs
unless you stang is a hatch you will have to. A dual 12 ported box will be a big box and while it may fit in the trunk, it will not fit through the opening into the trunk and there for not fit.
