Parrot Bluetooth with Shaker 1000
I'm interested in installing a Parrot CK3000 in my 05 GT with Shaker 1,000... Has anyone done this? Crutchfield does not have a harness to plug this in, so I wondered if it is possible/feasable and if the automatic mute feature would work.
Thanks for any insight you can provide.
http://www.quickconnectproducts.com/...ind.php?id=176
u will need to install a relay to shutoff the shaker amps
not a hard install at all
Please do..
I've just installed Parrot MKi9200 on my Shaker500 system but the Shaker doesn't seem to be working with it.
I used the safewireless plug-n-play harness, perhaps you or anyone could recommend a better solution that will get the Shaker to work with it.
Thanks.
Thanks.
JoshyGT
Sep 19, 2017 08:52 PM
