Amp in the trunk - power?
Old Mar 23, 2009 | 05:08 AM
nannerpuss's Avatar
nannerpuss
Default Amp in the trunk - power?
I plan to have a 3.5mm audio run to the amp inputs, for mp3 players, and then run wires back to the deck area...
My question is: how can I get sufficient power to the amp? It's 40x4 sony...
Should I make a custom mount where passenger's feet are or something?
Please help!
Old Mar 23, 2009 | 11:00 AM
ttocs's Avatar
ttocs
I have no clue what you are talking about, or what you are asking. Get power to the amp? You mean the +12vdc?
Old Mar 23, 2009 | 04:42 PM
todd217's Avatar
todd217
if u are talking about using a mp3 to drive the amp directly your amp may not like it. if u are talking about about the power wire no less than good 10awg wire. 8awg would be better because 10awg limits u a lot.
Old Mar 23, 2009 | 05:36 PM
nannerpuss's Avatar
nannerpuss
Yes...and ground...I want to put the amp in the trunk so that it is hidden and safe.
Yes, I want to run the mp3 player directly to the amp's rca inputs...
would it be safe to do a test hookup and just set the amp against the carpet and see if it will work, or does the wire still need to be thicker?
The amp is only 40x4 with a 10 amp fuse so I assume it's not going to need as much as if I would have it power subwoofers....
Old Mar 23, 2009 | 06:25 PM
todd217's Avatar
todd217
it will play if u hook it up directly. the problem may be that the output signal may be too much. if u are set on doing it try this at your own risk. turn the amp gain all the way down then turn the mp3 up and begin turning up the gain at little at a time. if at any time it starts to sound bad stop and turn the gain back down a little.
Old Mar 23, 2009 | 06:33 PM
ttocs's Avatar
ttocs
I am not trying to be mean but I don't think you really understand what needs to happen with the amp and all the wiring that is needed to install it. I would recomend seeking the closest pro installer to help you.
Old Mar 27, 2009 | 09:13 PM
altonc27's Avatar
altonc27
first off you need to get a head unit with aux inputs and get a 3.5mm aux adapter from walmart. that way you will actually be able to control everything from the HU instead of messing with the amps gains and everything. if u dont wanna do that just get a FM modulator and hook your mp3 player to it.
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:58 PM
